1. delta7's Avatar
    What is the problem? Is this a note 4 issue or just a issue with the headphones, I have the tracks air by sol and Motorola.
    06-03-2015 03:36 PM
  2. sparksd's Avatar
    06-03-2015 04:12 PM
  3. delta7's Avatar
    Yes seems like it, music will just cut off for like 30 seconds
    06-04-2015 10:31 AM
  4. sparksd's Avatar
    That's significantly different and worse than what others (including myself) are experiencing, that being a "hiccup" or momentary skip every minute or two, not total dropout for tens of seconds. That sounds more like a total disconnect/reconnect cycle.
    06-04-2015 10:55 AM
  5. delta7's Avatar
    So go back to sprint? Sell the phone?
    06-06-2015 01:44 PM
  6. delta7's Avatar
    It's the first day buy, I got in on the 200 solar promotion. What you think?
    06-06-2015 01:45 PM
  7. delta7's Avatar
    I have a Bluetooth speaker that seems to work better. Maybe the headphones just suck.
    06-06-2015 01:45 PM
  8. sparksd's Avatar
    Do you have any chance to try another set of Bluetooth headphones to determine if it's the particular pair you have or the phone itself?
    06-06-2015 05:21 PM
  1. Replies: 45
    Last Post: 06-10-2015, 07:30 PM
  2. Keep G4 or S6 Edge?
    By aaronc_98 in forum LG G4
    Last Post: 06-05-2015, 04:58 PM
  3. Dalvik cache and integration in to ROM
    By kmtm in forum General Help and How To
    Last Post: 06-04-2015, 09:44 AM
  4. Emails stay until I delete from phone?
    By dc9mm in forum Motorola Droid Mini
    Last Post: 06-03-2015, 08:40 PM
  5. Why require two separate APNs for one android phone?
    By quelquehomme in forum Ask a Question
    Last Post: 06-03-2015, 02:38 PM
