1. BennyBlanco99's Avatar
    Like many of you I am having a few small issues with my Note 4 since the Lollipop update. I have finally decided to go ahead with a factory reset but for the life of me I cant figure out how to back up all my data.
    What I have done so far:
    1) Turned on Kies air on my cell and laptop and connected the 2. I can see all the info from my phone on my laptop, but dont see any kind of option to backup or restore data.
    2) Plugged phone into laptop and connected Kies. Phone will not connect to Kies and gives me a pop up saying that my phone is better served using the Samsung Smart Switch App. I downloaded the app but it appears to only be if you are switching from phone to phone, again I dont see anything for only backing up or restoring a phone.
    Those of you who have done the factory reset, how did you do it and how did you backup all your info??
    06-03-2015 03:39 PM
  2. Miller6386's Avatar
    I let all my contacts back up to Google, transfer any photos or videos to SD card. Anything else I don't need so it goes.
    Note 4Tified
    06-03-2015 03:51 PM
  3. Rukbat's Avatar
    Backing up manually is more difficult than using Kies, but it's also more complete. See Backing up an Android Device. All the apps mentioned are free.)
    06-03-2015 03:57 PM
  4. brothamoveson's Avatar
    I do what miller 6386 says contacts backed up by Gmail, and send all files in internal memory that i want to save to sd card.
    06-03-2015 04:02 PM
  1. Replies: 6
    Last Post: 06-05-2015, 03:59 PM
  2. How to delete a blank home screen page?
    By Ace H in forum Samsung Galaxy Tab Pro 8.4
    Last Post: 06-03-2015, 05:39 PM
  3. Can I use a keyboard to emulate a virtual MOGA controller?
    Last Post: 06-03-2015, 03:34 PM
  4. How do you email photos?
    Last Post: 06-03-2015, 03:30 PM
  5. Why can't I see photos in Aviary on my pc?
    By AC Question in forum Samsung Galaxy S3
    Last Post: 06-03-2015, 03:11 PM
