1. Douglas Yarnold's Avatar
    I want to buy a Charging Cradle for my Samsung Note 4, however they all require QI Integration. There are numerous products out there, so what are your suggestions?
    And, while I'm on the subject of Charging Cradles, which one is best?
    06-07-2015 11:54 AM
  2. coolbreeze78's Avatar
    1. Official Samsung Qi back. Downside: no cases fit well, it makes the phone thick and slippery.
    2. Official Samsung Qi S-View. Downside: expensive, heavy and thick. Plus you have to deal with the flap.
    3. Shady Chinese sticker. Downside: 3rd party thing that may not be 100% safe and is probably janky. Plus, changing batteries is a PITA.
    Best Qi cradle? Tylt Vu, full stop.
    geekaren and Douglas Yarnold like this.
    06-07-2015 12:08 PM
  3. Neo_ii_Droid's Avatar
    I was about to suggest that to. Available here: TYLT VU QI Wireless Charging Pad - Android Wireless Charging - ShopAndroid
    Douglas Yarnold likes this.
    06-07-2015 12:13 PM
  4. Douglas Yarnold's Avatar
    Thanks for the info. Looks like a good product, but the problem I might have is that I have my Note 4 in a Unicorn Beetle Case, which some people say interferes with wireless charging. Ive used other cases, but their clips would break, the Beetle is fantastic. I guess I could try this wireless charger and hope for the best.
    06-07-2015 12:41 PM
  5. trucksmoveamerica#AC's Avatar
    If you use the Samsung back there's a good chance it won't fit case anymore. Then you have to use the third party inserts mentioned above, but I found the 2 I bought got the phone pretty hot, the Samsung back does not. Tylt also has a qi charger insert, haven't tried theirs.
    The tylt charging pad listed above is awesome, works great.
    06-07-2015 02:56 PM
  1. Why isn't my Metal band flush to the phone?
    By salsaverde in forum Samsung Galaxy S6
    Last Post: 06-11-2015, 01:57 PM
  2. Replies: 1
    Last Post: 06-08-2015, 03:20 AM
  3. Difficulty connecting to Wi-Fi
    By cb2367 in forum Motorola Droid Turbo
    Last Post: 06-07-2015, 11:21 PM
  4. Will my rapid charger for the Note 3 work with the Note 4?
    By AC Question in forum Chargers and Batteries
    Last Post: 06-07-2015, 11:57 AM
  5. Replies: 1
    Last Post: 06-07-2015, 11:22 AM
