1. jwt873's Avatar
    I've got a Note 4 running under Rogers Cellular in Canada. (The Canadian version of AT&T)
    I get the odd annoying spam phone call. So, from my phone app screen, I went in to Settings, -> Call Rejection, -> Auto reject mode -> Then I set it to "Auto Reject" numbers. Then, I put the offending phone numbers in my "Auto Reject" list.
    Well.. this does ignore the spam calls. My phone doesn't ring.. But, these calls pass through to my voice mail and sometimes I get bits of recordings like: "lower interest rates" or "you've won a cruise". I wind up having to skip by them when reviewing my voice mail.
    I had a Note 2 running under the same carrier. When I rejected a call, it was gone. Nothing went through to my voice mail. But I haven't had this success with my Note 4.
    Is there a way to completely kill an unwanted call with the Note 4?
    06-08-2015 03:13 PM
  2. sweetypie31's Avatar
    I use the Mr numbers app. I can either set it to hang up on the blocked numbers or send it straight to vm.
    06-08-2015 07:27 PM
  3. Kelly Kearns's Avatar
    This is how the auto reject works and did with the Note 3 also. It basically sends the call to voicemail.
    06-08-2015 10:23 PM
  4. GregMargie's Avatar
    I use the Mr Number app as well. It works great!
    06-09-2015 02:17 PM
  5. jwt873's Avatar
    Thanks all.. I guess I'll try Mr Number.
    06-09-2015 08:14 PM
  6. beh's Avatar
    I used to use Mr. Number and it works very well. However, it also leaks your phone number over the internet (at least it did when I was using it) and it is not an encrypted link. If this isn't an issue for you Mr. Number is a good choice.
    06-10-2015 10:58 AM
  7. smoothrunnings's Avatar
    Works for me I am on WIND Mobile.
    06-10-2015 01:07 PM
  1. How to Stop vibration for call connection??? PLease help!
    Last Post: 06-16-2018, 01:08 AM
  2. Replies: 1
    Last Post: 06-11-2015, 09:52 AM
  3. Problem detecting the phone in my laptop
    By kmtm in forum General Help and How To
    Last Post: 06-10-2015, 03:39 PM
  4. Why is Sync currently experiencing problems?
    Last Post: 06-08-2015, 12:48 PM
  5. losing data on call from 4g lte to 1x
    By mariusp1p1 in forum Ask a Question
    Last Post: 06-08-2015, 11:37 AM
