How can I have my Note 4 auto-answer when paired with my truck?
A
AC Question
have Note 4 auto answer when paired with my truck
could set my infuse so that it would auto answer on second ring when paired with my truck. Can't find settings to do this on my Note 4
itguyjax8430
Retired Moderator
Mar 15, 2013
6,822
Re: have Note 4 auto answer when paired with my truck
Welcome to Android Central!
Go to the phone dialer, go to the settings in the phone dialer, and go to answer and ending calls, you can use your voice to answer.
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
Or you could set up a Tasker task to "Take call" if the phone rings when it's connected to the truck.
rrspikes
102
Tasker is awesome but there's no need for it here.
The ability to answer calls when connected via BT is already built into the phone.
Open dialer
Open menu (3 dots in upper right)
Select settings
Select calls
Select call accessories
Select automatic answering
Default is 2 seconds but can be changed to 5 or 10 seconds.
kirk781
