1. adnanrider's Avatar
    I bought note 4(nm-910c) 4 days back and I also updated to lollipop.
    But I'm not experiencing a great battery life.
    I had to switch mobile network to 2G(gsm)only and power saving to see my battery drain to 50% in 4/5 hours with only WhatsApp used in Wi-Fi. I can post the battery usage screenshot here.
    Is this normal?
    06-09-2015 08:00 AM
  2. adnanrider's Avatar
    This is with 2G network, power saving and brightness kept at least.
    Attached Thumbnails Can someone say if this is normal battery life for note 4?-screenshot_2015-06-08-18-00-24.jpg
    06-09-2015 08:05 AM
  3. belodion's Avatar
    What is your screen-on time, and screen brightness?
    06-09-2015 03:54 PM
  4. soldier45's Avatar
    Must do a hard reset for batttery life to come back after updating to lolipop. Use Samsung Kies online to keep your files while doing hard reset.
    06-09-2015 05:11 PM
  5. muzzy996's Avatar
    I dont necessarily think this is bad battery life. The OP says just 4 to 5 hours of use but the battery chart covers 11:00 to 18:00 so that's 7 hours . . Just a guess but it looks like 3 hours of SOT if not more based on the SOT graph. When screen isn't on the battery curve is fairly flat and the device appears to deep sleep (looking at the 15:00 to 17:30 range).
    Seeing other battery stats pages and getting a true idea of SOT would help. Then again, with LP it's even harder to figure out what the heck is eating battery now. Nothing beats having full access to stats through root.
    06-10-2015 12:04 AM
  6. adnanrider's Avatar
    I'll try running a 100%to 10% discharge and post my graph here. I had hard reset,cleaned the cache after the update to lollipop too.
    06-10-2015 05:50 AM
  7. adnanrider's Avatar
    I appreciate the help!!!
    06-10-2015 05:51 AM
  8. Trees's Avatar
    https://play.google.com/store/apps/d....bbm.pro&hl=en has helped me better understand battery life details and which apps/processes are using CPU, memory, cell radio, etc.
    06-10-2015 07:43 AM
  9. Kronko's Avatar
    Can someone say if this is normal battery life for note 4?-uploadfromtaptalk1433949236554.jpg
    Sent from my SM-N910V using Tapatalk
    06-10-2015 11:14 AM
  10. smoothrunnings's Avatar
    Is this normal?
    I use 4G on my Note 4 and get about a day and half of battery life before I need to start charging it.
    06-10-2015 02:11 PM
  11. muzzy996's Avatar
    To be honest I find the best way to figure out battery life is to start fresh with a full battery, connected to wifi, clearing cache in recovery, rebooting, unplugging and then letting the device sit for a couple of hours with screen off. On first wake, jump into battery stats and look at the list of services and applications to see what used battery the most. Easiest way to accomplish this is fully charge before bed then prep and unplug. Wake up in the morning and observe.
    While asleep the device shouldn't wake up frequently. If it is, tracking down the applications that wake it takes effort and patience. Rooted users have it easy since battery stats are more detailed with root permissions, not to mention more tools to handle wakelocks.
    Sent from my SM-P900 using Tapatalk
    Kane89 and Trees like this.
    06-10-2015 10:53 PM
  12. adnanrider's Avatar
    In 3g always...WiFi is on..location is off..
    Attached Thumbnails Can someone say if this is normal battery life for note 4?-screenshot_2015-06-11-08-56-59.jpg
    06-11-2015 01:00 AM
  13. adnanrider's Avatar
    No power saving too
    Attached Thumbnails Can someone say if this is normal battery life for note 4?-screenshot_2015-06-11-08-57-51.jpg
    06-11-2015 01:01 AM
  14. adnanrider's Avatar
    Battery usage
    Attached Thumbnails Can someone say if this is normal battery life for note 4?-screenshot_2015-06-11-09-02-36.jpg
    06-11-2015 01:03 AM
  15. adnanrider's Avatar
    Screen time
    Attached Thumbnails Can someone say if this is normal battery life for note 4?-screenshot_2015-06-11-09-03-13.jpg
    06-11-2015 01:03 AM
  16. adnanrider's Avatar
    Gsam
    Attached Thumbnails Can someone say if this is normal battery life for note 4?-screenshot_2015-06-11-09-07-21.jpg
    06-11-2015 01:08 AM
  17. muzzy996's Avatar
    That wake time with screen off is a concern. Like I noted above clear cache in recovery and do a clean boot. It's best to test on clean boot without ever launching anything, wait a couple of hours and then check battery stats to see what floats to the top.
    06-11-2015 03:13 AM
  18. smoothrunnings's Avatar
    IF YOU HAVE A BATTERY PROBLEM THEN YOUR DOING SOMETHING WRONG!!
    See this post.
    http://forums.androidcentral.com/sam...ml#post4472605
    I don't have a battery problem with my Note 4. It's not rooted either.
    06-11-2015 06:13 AM
  19. Trees's Avatar
    I'd say for adnanrider, you're getting a full 24 hours battery life with almost half of that being active usage, and over nine hours screen time according to the GSAM screenshot. In my view, thats quite good.
    06-13-2015 12:03 PM
  1. Why isn't my Micromax s300 headphone working?
    Last Post: 04-30-2017, 09:23 AM
  2. Replies: 3
    Last Post: 11-15-2016, 09:44 PM
  3. How do I delete my Galaxy Note 4 'T-Mobile' logo?
    By snozzlebobby in forum Ask a Question
    Last Post: 05-24-2016, 02:31 PM
  4. Replies: 1
    Last Post: 06-09-2015, 06:48 PM
  5. Replies: 1
    Last Post: 06-09-2015, 08:07 AM
