10-02-2015 05:53 AM
28 12
tools
  1. steeledarren's Avatar
    Anyone in the UK having issues in playing video stream ( quick news clips )within the BBC iplayer app via their Android device ? I have a new Note 4 updated to the new Lollipop software. I think it may a lollipop issue with the actual iplayer app. I've tried most fix options but to no avail. When trying to open a video clip my device 'trys' to play the clip but a blank black video page is all I get with the clip time status displayed as normal at the bottom of the screen , this then forces my Note 4 to freeze , leaving me no other option to remove battery to even restart.
    06-13-2015 01:22 PM
  2. josepepepe771's Avatar
    mate, I have the same issue. I think its lollipop too. Hopefully the BBC guys or Android with come with an update that can fix this soon
    06-13-2015 01:48 PM
  3. Mannikon's Avatar
    BBC are slow to fix issues. This current problem affects many other Android devices and has been going on for some time now. This is why the app gets a low rating on Play Store. Free app from an arrogant UK public institution, why should they care? Video streaming works perfectly with all other providers, just not the BBC.
    06-13-2015 05:50 PM
  4. steeledarren's Avatar
    Thanks guys ! That's confirmed my suspicions !.
    06-14-2015 05:52 AM
  5. Mark Toye's Avatar
    Exactly the same for me. Especially embarrassing as Apple fan boys don't have the problem on their devices. I contacted BBC and they insist it is fixed by an update (android not BBC of course). All other media serviced work fine with lollipop. Lazy BBC.
    06-15-2015 03:55 AM
  6. amer369's Avatar
    Your note 4 can download content and play, you'll be able to stream to a chromecast but you just can't stream to the phone.
    I've been in touch with BBC iPlayer "tech support" (lol), they give a standard response that their tech team believes a update remedies the problem... Therefore it's a Android issue. They tell you to contact Samsung or carrier knowing full well they're passing the buck.
    They won't acknowledge it's their app that's at fault blaming the OS. They won't even tell you what update you need, website says the problem is 5.0.2 but I have 5.0.1 and have the problem.
    My other theory is that their tech are so incompetent that they've told their less tech savvy management it's lollipop and their app is fine. So now they actually believe their apps all good.
    They are arrogant but what can we do..
    06-17-2015 07:02 AM
  7. PublicImageLtd's Avatar
    Lollipop culprit.
    06-30-2015 02:49 PM
  8. slatermethuen's Avatar
    Does anyone know if upgrading from Lollipop to KitKat will fix the iPlayer issue?
    08-19-2015 03:33 AM
  9. Rarry's Avatar
    Keep trying. Maybe the failures will show up in their usage statistics and they'll do something about it.
    There is an update coming in the next few days with some good new features. Fingers crossed it'll work on the note 4.
    BBC iPlayer now lets you pause and resume shows on different devices http://www.engadget.com/2015/08/19/i...device-resume/
    08-19-2015 10:09 AM
  10. slatermethuen's Avatar
    I am unable to keep trying. In order to try and get iPlayer working I tried uninstalling it with the intention of re-installing again, but the BBC have pulled the app from the Play Store for Note 4 devices.
    Hopefully the new update will be available for Note 4s, but I doubt it.
    08-20-2015 02:02 AM
  11. Rarry's Avatar
    Still can't get the update but I used 'app backup and restore' app to copy the apk for the media player and iPlayer from my Nexus 7 and installed to the Note 4. It won't play streamed content but downloading and playing does work.
    08-30-2015 07:43 AM
  12. Rarry's Avatar
    Just noticed that iplayer (the one I copied from Nexus 7) works streaming to chromecast, so that's something.
    09-03-2015 07:48 AM
  13. PublicImageLtd's Avatar
    Iplayer ****E, it's never worked on my note 4,but works on my Tab A. ****E BBC.
    09-08-2015 08:19 AM
  14. Common Sense Is 3's Avatar
    Hi, do you or anyone else that has managed to get this working on Note 4 or other previously failing version on any device to work know which version it is? I really want to try but I have tried a few versions now and cannot find the correct one. Please help. Thank you.
    09-22-2015 11:03 PM
  15. Rarry's Avatar
    4.11.0.169 is there one I copied from Nexus 7.
    3.1.8 is the BBC media player version.
    I checked it's still the same, it just freezes trying to play progs, but can download and play progs and will also stream to Chromecast.
    That's fine for most uses. If you want live streaming take a look at Filmon app which live streams most UK TV free in (low) SD and also works with Chromecast.
    I checked that out the other day when someone mentioned it in another post. It looks good so long as they don't start limiting it or adding ads and will work abroad too.
    09-23-2015 02:48 AM
  16. Rarry's Avatar
    BBC wants you to test iPlayer app features before they launch http://www.engadget.com/2015/09/22/b...r-mobile-beta/ via Engadget Android
    Join up as a tester quickly! There's only 1000 'spots'. If a few Note 4 users enrol maybe we can push to get a working version. It only takes a second to click on a link.
    09-23-2015 05:44 AM
  17. slatermethuen's Avatar
    Now that I've installed 5.1.1 on my Note4, iPlayer has started working again
    Currently on 4.9.0.259 and media player 3.1.8.
    I'm still unable to get the latest version since the play store is still saying it is incompatible with my device.
    I've signed up for the beta programme, but cannot leave feedback, since this is done from within the app, which I am unable to install!
    09-24-2015 07:54 AM
  18. Rarry's Avatar
    I signed up yesterday and today I've got a new beta version and it WORKS! So that's good news, looks like the Note 4 will soon get a working iPlayer once the beta testing is finished.
    09-25-2015 05:38 AM
  19. t11rmh's Avatar
    My Note4 got the BBC Iplayer update today and it works again. Happy about this.
    Posted from my kicking Samsung Note4 on Lollipop 5.1.1
    09-28-2015 05:24 PM
  20. PublicImageLtd's Avatar
    I got the update today, still doesn't work.
    09-29-2015 01:04 PM
  21. t11rmh's Avatar
    There was another update again today. Two days in a row so try it again.
    09-29-2015 02:18 PM
  22. PublicImageLtd's Avatar
    I did the update just an hour or so ago.
    09-29-2015 02:21 PM
  23. Rarry's Avatar
    My working iPlayer (beta?) is 4.11.1.100 and my unlocked Note 4 is running 5.0.1
    09-29-2015 03:30 PM
  24. t11rmh's Avatar
    Well, must be something specific to your phone then.
    09-29-2015 03:36 PM
  25. evohicks's Avatar
    Hope this gets sorted out soon, haven't been able to use it for a while now, any beta build links about anywhere?
    09-29-2015 05:39 PM
28 12
  1. Why does my battery drain so quickly with S Plus?
    By advicement in forum Batteries
    Last Post: 06-17-2015, 04:11 PM
  2. Mobile Data issues after last ota update?
    By ratpakk2 in forum ASUS ZenFone 2
    Last Post: 06-15-2015, 02:58 AM
  3. Why am I unable to find 'applications' on my Samsung Note II?
    By AC Question in forum Samsung Galaxy Note 2
    Last Post: 06-14-2015, 03:09 AM
  4. Sudden Issue Charging (Z3v)
    By Hemdroids in forum Sony Xperia Z3
    Last Post: 06-13-2015, 03:06 PM
  5. Sudden Issue Charging
    By Hemdroids in forum Sony Xperia Z3v
    Last Post: 06-13-2015, 01:21 PM
