1. MTHall720's Avatar
    First let me say no other phone or device of any kind in our house has any problems with connecting to our home wifi.
    Don't know how to make it connect to my home WiFi automatically. Sometimes it will log on immediately when I am in range, automatically, and remembers my password. However sometimes I have to use my WiFi app to make it connect. To make matters even more frustrating is that it refuses to accept my password to log onto my home WiFi. In a public place, which has a working WiFi connection it usually does fine.
    This is really getting on my nerves since I just got the phone less than two weeks ago. I am an AT&T customer. I could take it back, pay a restocking fee, and get Iphone 6 like my wife did, but I am crazy about the screen size and resolution of this phone.
    06-13-2015 02:10 PM
  2. Golfdriver97's Avatar
    Have you tried rebooting the router? Also, in the advanced settings of wifi, there may be an option called avoid poor connections. See if that is checked or on.
    06-14-2015 07:31 AM
  3. PlanetPluto7's Avatar
    My Note 4 on 5.1.1 just started this yesterday. Gets as far as "obtaining ip address sometimes but usually hangs at "connecting" and goes off on another search. It was working fine since forever before yesterday. No changes in the routers. Last try was boosting the routers signal strength and then "forgetting all the connections; no help. Rest of the LAN is fine.
    06-14-2015 11:01 AM
  1. Calendar will Synch, but with limits. Is this normal?
    By TB222 in forum General Help and How To
    Last Post: 06-14-2015, 03:44 PM
  2. How to unlock PIN password? actually I forgot my password
    Last Post: 06-14-2015, 04:44 AM
  3. Note 4 factory reset
    By broom9700 in forum Samsung Galaxy Note 4
    Last Post: 06-14-2015, 01:39 AM
  4. how do I delete pdf files from my android ultra?
    Last Post: 06-14-2015, 01:32 AM
  5. Google is disabling my grandson's account, how can I stop this?
    By Seawind36 in forum General Help and How To
    Last Post: 06-13-2015, 05:40 PM
