1. no1's Avatar
    Over the last several days I have noticed significantly higher battery consumption than ever before. I have not installed any new apps lately. Android System appears to be the culprit. I have wiped the cache without any change in results.
    I am running Lollipop as released by AT&T earlier this spring, and I had no issues until very recently. I have regularly gotten 4 hours of screen time over a 16-hour period.
    Any suggestions?
    Anyone else seeing this?
    Attached Thumbnails Android System Battery Drain-screenshot_2015-06-16-17-45-08.jpg   Android System Battery Drain-screenshot_2015-06-16-17-45-28.jpg
    06-16-2015 05:52 PM
  2. FSchmitthammer's Avatar
    I had the same issue on my Verizon Note 4. I had to do a factory reset. Oh what a difference? I loaded the same apps and the phone lasts 19 hours now.
    Tatt2014 likes this.
    06-16-2015 06:08 PM
  3. LordAndroid's Avatar
    I currently have this same drain on mine i factory reset it no difference for me. Its annoying
    Sent from the mighty Tab S
    06-16-2015 07:59 PM
  4. no1's Avatar
    Are you also running stock AT&T?
    06-17-2015 05:47 AM
  5. LordAndroid's Avatar
    Yes im totally stock
    07-21-2015 07:50 PM
  6. mountainbikermark's Avatar
    I do a cache partition wipe every time mine starts doing that. It's faster and easier than a total reset and works for me.
    Support Our Troops !!!
    Beast Mode 4
    Ntchwaidumela likes this.
    07-21-2015 08:44 PM
  7. Ntchwaidumela's Avatar
    Beast Mode 4
    I was going to suggest this same thing. It's faster and much easier than factory reset. And it works for me every time. In fact, I do it about once a month or so, just to keep things snappy. I'm not saying to disregard a factory reset. But I would only do it when it's absolutely necessary.
    07-22-2015 12:17 PM
  8. bobxxz's Avatar
    In another thread someone said to turn off enhanced 4G LTE services under mobile network. It definitely stopped my high consumption android system. Try that out.
    LordAndroid likes this.
    07-22-2015 02:31 PM
  9. LordAndroid's Avatar
    Thank you for suggesting this. Finally something that helped it didnt stop the drain completely but it did help. I've been stressed out about this since April. Gone are the days of seeing 25% - 40% drain. The most i get is 20%. Thank you again for both reducing this battery drain and my stress.
    07-30-2015 07:05 PM
  1. Android Central Photo Contest: Light bulb
    By Andrew Martonik in forum Photo Contests
    Last Post: 07-01-2015, 12:10 AM
  2. Replies: 1
    Last Post: 06-19-2015, 08:08 AM
  3. Why is my battrey draining so fast?
    Last Post: 06-16-2015, 06:55 PM
  4. Replies: 1
    Last Post: 06-16-2015, 06:54 PM
  5. Welcome to android fragmentation, Apple.
    By syspry in forum iPhone/iOS
    Last Post: 06-16-2015, 05:26 PM
