1. AC Question's Avatar
    I have tried everything to connect my brand new Gear 2 Neo to my Note 4. I have reset the Neo, uninstalled the Samsung Gear Manager several times, paired and unpaired the Gear, all with no luck. My phone will link to the watch via blue tooth but Gear Manager won't connect to Gear. The app perpetually says "Connecting to Gear..." but never does. Any suggestions on how to resolve this issue would be helpful. Respectfully.
    06-17-2015 09:34 PM
  2. Catherine Pearson's Avatar
    i can get mine to connect after resetting both devices but it won't stay connected. Seems to be a recent fault as it was working perfectly up until 2 weeks ago. if you go to the bluetooth on the note 4 it shows the gear and will connect momentarily that way but only for a few minutes at most.
    08-04-2015 11:37 AM
  3. pduffer's Avatar
    I bought a gear 2 neo last Friday. So far it seems to be connecting OK.
    Sent from my SM-N910V using Tapatalk
    08-04-2015 03:23 PM
  4. pduffer's Avatar
    Did you ever get your problem resolved? If so, how?
    08-04-2015 03:23 PM
  1. Replies: 16
    Last Post: 01-31-2017, 07:40 AM
  2. Do you have a Gear VR on T-Mobile?
    By Xm_jdm in forum Samsung Galaxy Note 4
    Last Post: 06-18-2015, 01:27 PM
  3. Replies: 1
    Last Post: 06-17-2015, 09:12 PM
  4. Replies: 0
    Last Post: 06-17-2015, 08:26 PM
  5. Replies: 1
    Last Post: 06-17-2015, 08:21 PM
