1. kittenphelia's Avatar
    Where on earth is the setting for enabling and disabling the restriction of background data? I can't find it anywhere.
    Elaine Stewart likes this.
    06-19-2015 12:13 PM
  2. lsmachado's Avatar
    Settings > Connections > scroll down to Data Usage > tap the 3 vertical dots in the upper right corner > tap "Restrict Background Data".
    Hope this helps.
    06-19-2015 07:16 PM
  3. kittenphelia's Avatar
    Thanks for responding, but the only options are Hide WiFi, Mobile Networks, Mobile Hotspots, Show units and Help. There's no option to restrict background data.
    06-19-2015 10:35 PM
  4. Neo_ii_Droid's Avatar
    Just curious here, I have the VzW SGN.IV and is this what you're seeking to secure (in this case "restrict"?)?
    Don't know if the above representation is of some help to you. Hope you find what you're wanting to do.
    06-19-2015 11:52 PM
  5. lsmachado's Avatar
    I have at&t:
    Attached Thumbnails Note 4 Background Data Setting-screenshot_2015-06-20-09-26-25-1.jpg   Note 4 Background Data Setting-note062015_1_1-2.jpg   Note 4 Background Data Setting-note062015_2-1.jpg
    06-20-2015 10:54 AM
  6. kittenphelia's Avatar
    Thanks guys, I just went there again and the option is there. Thank you so much for all the help, still not sure why it wasn't there in the first place lol
    06-20-2015 11:36 AM
  7. cordovavme's Avatar
    Sorry to bother you but I have the same problem. I can't take off background data restriction. It doesn't give me the option. Can you help me please?
    I have at&t:
    06-13-2016 01:11 AM
  8. cordovavme's Avatar
    I have at&t also but phone is through Verizon does that have something to do with it?
    06-17-2016 01:52 PM
  1. Can I install Samsung Galaxy Notes ROM on my Chinese Android Phone?
    By SAM SEVEN in forum General Help and How To
    Last Post: 06-22-2015, 08:54 AM
  2. Replies: 1
    Last Post: 06-22-2015, 08:40 AM
  3. Quick settings / touch screen help
    By oat77 in forum LG G4
    Last Post: 06-19-2015, 02:04 PM
  4. 5.1.1: Two quick notes
    By katmandoo122 in forum Samsung Galaxy S6 edge
    Last Post: 06-19-2015, 09:33 AM
  5. Why will my note 3 not send text?
    Last Post: 06-19-2015, 09:07 AM
