1. ggabu500's Avatar
    I have a new Samsung Galaxy Note 4 and a PAYG 500mb of data per month.
    So I do not waste my data allowance, I want to ensure I am using Wifi whenever and wherever possible, but also be able to rely on data usage when out of range of Wifi.
    I have both Wifi and data enabled, but how can I be sure the Wifi is being used in preference to data?
    06-23-2015 04:43 PM
  2. SpiritApps's Avatar
    As far as I know, if you enable Wi-Fi on your android(Settings --> Wi-Fi --> Wi-Fi set to ON), it will always prioritize your Wi-Fi over mobile networking. If there is no Wi-Fi available or device is not able to connect to it(for example, the Wi-Fi network is secured and you have not filled in right credentials(password)), your android phone will automatically switch to mobile network.
    Secured networks are indicated with a Lock icon. If your device finds a network that you connected to previously, it connects to it automatically(provided Wi-Fi is set to ON as explained above).
    marcclarke likes this.
    06-24-2015 02:46 AM
  3. goin_nil's Avatar
    Switch to airplane mode. Turn on Wi-Fi. This shuts off 4G.
    If you rarely make or receive phone calls, you are good. Most people text or instant message anyway. Maybe turn airplane mode off every hour to see if any one called.
    If you need frequent calls, this won't be a good solution.
    06-24-2015 09:09 AM
  4. beh's Avatar
    You may also set most apps settings to only connect over WiFi, but then if there is no WiFi connectable to your phone you will not have any connection when out of range of a WiFi network you phone can connect to.
    What I do is use WiFi only in town and either/or setting when on the road our out in rural areas. But if you are far enough out in the back of beyond and your cell service is through a 3rd party you could not only use data but be charged for it.
    06-24-2015 11:22 PM
  5. Jay Sacks's Avatar
    Also in wifi advanced settings make sure Smart Network Switch is unchecked. This will keep mobile data from taking over when wifi signal is weak.
    Sent from my SM-N910V using Tapatalk
    06-25-2015 01:52 AM
  1. Where is the keyboard theme on my LG G3?
    By AC Question in forum LG G3
    Last Post: 06-25-2015, 04:52 PM
  2. Why can't I add an account to my Huawei Ascend G7?
    By AC Question in forum Huawei Android Phones
    Last Post: 06-23-2015, 04:43 PM
  3. How can I root my Unnecto Air 4.5 running 4.4.2 KitKat?
    By Sturdyoak99 in forum Android 4.4 KitKat
    Last Post: 06-23-2015, 04:30 PM
  4. Replies: 0
    Last Post: 06-23-2015, 04:25 PM
  5. Why have I lost camera voice command on my Galaxy S5?
    By Alfonso the Great in forum Android 5.0 Lollipop
    Last Post: 06-23-2015, 04:20 PM
