1. doublestack1's Avatar
    Cannot find a way to default the sound boost option when on calls. The earpiece volume is just too low on my VZW Note 4. With the boost option is is tolerable. Any advice is greatly appreciated.
    Pete
    tituswife likes this.
    06-23-2015 10:56 PM
  2. kami8586's Avatar
    I believe in lollipop it was removed I'm on Verizon as well
    06-24-2015 06:11 AM
  3. doublestack1's Avatar
    Is your call volume low when you use the earpiece? I use mine a ton and cannot believe how low the volume is. I have all the settings set at their highest level. Do any of the boost apps actually work?
    06-24-2015 11:28 PM
  1. Travel Chargers for Zerolemon batteries.
    By Kane89 in forum Samsung Galaxy Note 4
    Last Post: 06-24-2015, 11:37 AM
  2. Nexus 5 (White 16 GB) for Asus Zenwatch or other Android Wear
    By JRDroid in forum Marketplace Archive
    Last Post: 06-24-2015, 01:01 AM
  3. Replies: 1
    Last Post: 06-24-2015, 12:09 AM
  4. Charging my Galaxy S6 for the first time?
    By Sulejman Hadzic in forum Samsung Galaxy S6
    Last Post: 06-23-2015, 10:27 PM
