1. AC Question's Avatar
    It started last night. I came home and found my phone dead. It wouldn't power on. When I plugged it in it stated it had 73 % power and I booted it up and everything and everything works fine. I took it off the charger after getting to 100% and then it dies again won't power on, nothing until I plug it in and then it shows that battery and shows power at 100%. Right now it is working at the moment but it could do it again as last night it worked for a bit then did it again about 4 or 5 times before I finally left it on the charger. Only had the phone for 6 months. Could it be a bad battery.
    06-26-2015 09:26 AM
  2. Alex Wetzel's Avatar
    You either have a defective phone or a bad battery. I'd do a factory reset to see if that helps. Then as a last resort, have it replaced. Hope this helps.
    06-26-2015 10:00 PM
  3. muzzy996's Avatar
    Why advise the user to erase the phone rather than the obvious choice which is to visit a cell phone store and try swapping a charged battery into the device? If it works problem solved, buy a new battery and then work on getting a replacement under warranty....the factory reset should only apply after hardware is ruled out.
    06-26-2015 10:17 PM
  4. Alex Wetzel's Avatar
    Didn't think about that. Thanks!
    06-26-2015 10:36 PM
  1. Remove camera icon from swipe lock screen on Moto G with 5.1?
    By Madd54 in forum General Help and How To
    Last Post: 11-02-2015, 05:46 PM
  2. Replies: 22
    Last Post: 06-30-2015, 05:13 PM
  3. Why did my phone shut off on its own, and won't turn back on?
    By Vanessa Jackson Calloway in forum General Help and How To
    Last Post: 06-29-2015, 12:20 PM
  4. Which should I get the Samsung Galaxy S3 (2012) vs. Moto E (2015)?
    By Icarus3000 in forum General Help and How To
    Last Post: 06-29-2015, 12:11 PM
  5. Is that the phone I've seen on TV?
    By espio in forum LG G4
    Last Post: 06-26-2015, 11:05 PM
