1. rgn4's Avatar
    I've just got a new router that has ac wifi and can aggregate both bands for better coverage.
    How do I set up the Note 4 to use ac?
    The router has separate SSIDs for the two bands. Do I have to make them the same?
    07-01-2015 04:27 AM
  2. Alex Wetzel's Avatar
    The note 4 already come set up to use 802.11ac wifi. You just need to connect to your new router to use the faster network.
    07-01-2015 08:14 AM
  3. Alex Wetzel's Avatar
    As for the band's, one will most likely be 2.4GHz and the other one will be 5 Ghz.
    07-01-2015 08:17 AM
  4. rgn4's Avatar
    "You just need to connect to your new router to use the faster network."
    Er yes, but what do you mean by "connect"?
    The router has separate SSIDs for 2G and 5G. I can connect to either, but I'm only seeing that single band.
    07-01-2015 08:21 AM
  5. Compusmurf's Avatar
    Maybe start by telling us what router so folks can do some research?
    07-01-2015 08:51 AM
  6. rgn4's Avatar
    The router is a DrayTek 2860ac,
    But I guess the same principle applies for any router. After all if I visit an office or store with ac wifi I can't ask them what router they are using
    07-01-2015 09:01 AM
  7. D Android's Avatar
    Mine automatically connects to ac on 5G when in range, I didn't have to set anything up and SSIDs have different names and not hidden.
    07-01-2015 10:21 AM
  8. rgn4's Avatar
    D Android you gave me the hint.
    The SSIDs were both hidden. I made them unhidden and now the phone gets the full bandwidth when I connect to the 5G band.
    Thanks to you and the others for your help!
    D Android likes this.
    07-01-2015 12:07 PM
  1. Why don't I have wifi internet on my Samsung Note 10.1 2014?
    By AC Question in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 07-01-2015, 10:18 AM
  2. Replies: 1
    Last Post: 07-01-2015, 12:27 AM
  3. how to unstick the volumn up button on my samsung s4
    Last Post: 07-01-2015, 12:14 AM
  4. Why is my Audiovox tablet not booting up?
    By AC Question in forum Other Tablets
    Last Post: 07-01-2015, 12:08 AM
  5. Why won't my GS5 properly connect to my wifi?
    By The_Fresh_Prince in forum Samsung Galaxy S5
    Last Post: 06-30-2015, 11:41 PM
