1. MiniMendel's Avatar
    Hello, could you guy please check my battery life? I feel like it goes down very fast (compare to my previous LG phone)
    I charged my phone to 100% around 9am
    Then uses Internet (just Web browsing, no youtube) for about 50 minutes and the battery drains to 87%
    After that I wasn't on the phone for about an hour and a half also (I checked the battery when I came back...the % was okay)
    I start using Internet again (mostly google)
    Now the battery goes down to 70%
    Could you please check if this is normal ,or not.
    I got my first Note4 on Sunday but the battery drain was real horrible...almost 20%in an hour ...and i only use hangout app.
    so I request a new phone from the store. This one (got it on Tueday) is quite better. But I often see a quick drain of battery from time to time especially from 100% ->85% (within an hour)
    1.I set my phone to power saving mode
    2. I unchecked attached the auto-sync from all mail account (change it to manual) also my mail account has less than 50 mail so far.
    3. I turn notice message off from all my messenger apps (hangout ,line, FB)
    4. The only app I installed so far is Line application (other Note4 app are auto installed and I couldn't delete them)
    5) I got this phone yesterday (Tueday) and I have no files nor music in my phone yet)
    6) I often close all the window as soon as I finish so I don't leave app running on the back ground
    7) I often use Spen when applicable
    Attached Thumbnails Concern about battery-1435775037640.jpg   Concern about battery-1435775123498.jpg   Concern about battery-1435775382782.jpg   Concern about battery-1435775398780.jpg   Concern about battery-1435775408781.jpg
    Mangkudun Sati and vencistefi like this.
    07-01-2015 02:41 PM
  2. dedhedAndy's Avatar
    Doesn't appear to be a problem to me from the screen shots you attached. In the yellow circle it looks like it stayed pretty level. Only time it appeared to go down was when you were using it. If I remember correctly my note took a few days at first to normalize. After a few days and a few charges my battery seemed to get better. I don't see anything too alarming in your screen shots.
    Posted via Galaxy Note 4
    07-01-2015 02:50 PM
  3. bingdateneo2002.'s Avatar
    I see it as normal. But, If you have more time in charging, I would suggest not to fast-charge your battery - it shortens/wears battery life.
    Sent from my SM-N9005 using Tapatalk
    07-01-2015 09:21 PM
  4. Blacklac's Avatar
    Sounds about right. Browsing really hits the battery.
    07-01-2015 09:35 PM
  5. MiniMendel's Avatar
    Okay. If yall expert said it is normal then I am good with it ^_^
    My previous device (ILG...bough about 3 yr ago) is not a high tech smartphone (when compare to SS )
    So I was quite shock and have a concern about the battery life since my previous LG function quite different
    07-01-2015 09:45 PM
  1. Replies: 3
    Last Post: 07-02-2015, 06:16 AM
  2. Galaxy Tab 2 7.0 - battery will not charge
    By Haba9121 in forum Samsung Galaxy Tab 2
    Last Post: 07-01-2015, 11:44 PM
  3. Short term plea for battery/charger
    By jamielov in forum LG G4
    Last Post: 07-01-2015, 02:29 PM
  4. Is my GS4 active battery a bit broken?
    By scootervroom in forum Ask a Question
    Last Post: 07-01-2015, 02:18 PM
  5. Best places to get a new battery?
    By Brandwin in forum Samsung Galaxy Note 4
    Last Post: 07-01-2015, 01:08 PM
