1. Tylerr64's Avatar
    Hey guys I'm new here and really need your help!
    I have a Galaxy Note 4 with Rogers that I just got, everything works great except I cannot connect to my works wifi (walmart) My phone connects everywhere else and works except there. When I am in my wifi screen it says the connection is saved then says connecting and does the same thing back and fourth but will not connect? I have tried every trick in the book from what I know at least. My note is running Lollipop 5.0.1 if that helps.
    Thank you for anyone that can help me resolve this issue.
    07-05-2015 12:24 AM
  2. nahoku's Avatar
    The only time my N4 does this is when the password is wrong. It doesn't "tell" me the password is wrong, it just tries to connect, fails, tries to connect, fails, and so on. Maybe the password you're trying has been changed?
    07-05-2015 07:49 AM
  3. Tylerr64's Avatar
    I sent you a private message Nahoku. But for anyone else that wants to help my works wifi does not require a password you just connect to it and go to your browser and accept the login screen to use it. :/
    07-05-2015 01:18 PM
  4. nahoku's Avatar
    Got your PM but posting back here. I know you said you tried everything, so this next suggestion might be mute. Did you delete or "forget" the wireless profile for the Walmart wifi so the phone can try to rediscover it and try to connect to it again?
    07-06-2015 05:04 AM
  5. Tylerr64's Avatar
    Yes I have selected the forgot option several times and it still does the same thing.
    07-08-2015 02:45 PM
  1. Replies: 2
    Last Post: 07-05-2015, 09:30 AM
  2. Why is my device restarting over and over again?
    Last Post: 07-05-2015, 07:05 AM
  3. samsung galaxy s3 is non responsive!
    By mollyann in forum Ask a Question
    Last Post: 07-04-2015, 11:43 PM
  4. how to root oppo mirror 3?
    By mhaie027 in forum Oppo Find 5
    Last Post: 07-04-2015, 11:38 PM
  5. Why aren't my apps installing from unknown resources?
    By Ojasveer Srivastava in forum Android Apps
    Last Post: 07-04-2015, 11:34 PM
