1. robcassman's Avatar
    Any suggestions? Battery lasts about 8 hours total.
    07-12-2015 04:26 PM
  2. Javier P's Avatar
    Your screenshot shows a couple of things.
    You have very bad signal and your phone is going to use much more battery because of that, specially when using mobile data.
    Your awake bar is almost solid. It seems that you've got some background processes running almost non stop. Check in your battery stats which apps are using more battery. Also check your main sync/upload settings.
    07-12-2015 04:35 PM
  1. LG G4 white battery door
    By zxphenomenalxz in forum LG G4
    Last Post: 07-13-2015, 10:17 AM
  2. Replies: 3
    Last Post: 07-12-2015, 05:34 PM
  3. Samsung Galaxy S5 battery life/health.
    By Omar Moussa1 in forum Ask a Question
    Last Post: 07-12-2015, 02:17 PM
  4. Why doesn't the battery on my Samsung S5 tablet fully charge?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 07-12-2015, 07:29 AM
  5. Replies: 0
    Last Post: 07-12-2015, 06:14 AM
