1. sstephen17's Avatar
    Installed GSM a few weeks ago after noticing considerable drain on my battery (especially when I send/receive a lot of texts). Noticed that Android takes up a big chunk of the battery. Wondering if this is normal? I've done a factory reset and wipe my cache a few times a week.
    Android System eating up majority of battery-capture1.jpgAndroid System eating up majority of battery-capture2.jpg
    07-13-2015 06:11 PM
  2. goin_nil's Avatar
    ...Wondering if this is normal? ...
    Yes, it is.
    07-13-2015 09:18 PM
  3. LordAndroid's Avatar
    Android System eating up majority of battery-uploadfromtaptalk1436847957412.jpg same issue with me this is driving me nuts and its only when im on wifi. Android System eating up majority of battery-uploadfromtaptalk1436848028387.jpg
    Sent from my Awesome Note Quatro
    07-14-2015 12:27 AM
  4. Neo_ii_Droid's Avatar
    I've never really fully understood all of this "stats" and whatnot. Here's mine:
    Attached Thumbnails Android System eating up majority of battery-screenshot_2015-07-13-22-46-20.jpg   Android System eating up majority of battery-screenshot_2015-07-13-22-45-57.jpg   Android System eating up majority of battery-screenshot_2015-07-13-22-46-54.jpg   Android System eating up majority of battery-screenshot_2015-07-13-22-47-20.jpg
    07-14-2015 01:51 AM
  5. Princepia's Avatar
    Both of these battery stats indicate really really consistently poor cell signal. Those orange and yellow bars are draining your battery.
    07-14-2015 03:05 AM
  6. LordAndroid's Avatar
    I turn off mobile data once im using wifi
    Sent from the mighty Tab S
    07-14-2015 03:12 AM
  7. Neo_ii_Droid's Avatar
    I have Smart network switch enabled.
    07-14-2015 03:37 AM
  8. sstephen17's Avatar
    Which "category" if any, would MMS messages fall under? That is definitely my biggest battery drain. Even with a strong network signal (at home or work I'm usually at two or more bars 4G) and WiFi, if I get a bunch of MMS messages (>25 an hour), my battery literally drains 1% every five minutes.
    07-14-2015 01:16 PM
  1. Why does my voicemail notification keep popping up
    Last Post: 07-23-2015, 09:41 PM
  2. Replies: 15
    Last Post: 07-17-2015, 04:16 PM
  3. "Phone idle" battery drain
    By welle wexetemovski in forum Android Apps
    Last Post: 07-13-2015, 05:58 PM
  4. Replies: 1
    Last Post: 07-13-2015, 05:34 PM
  5. How can I delete the voicemail icon at the top of my phone?
    Last Post: 07-13-2015, 05:19 PM
