08-12-2015 05:44 AM
33 12
tools
  1. Sonny Shah's Avatar
    So I've been having the same battery drainage issues with my Note 4 as well. I got mine back in October and still have the original battery. Yesterday my phone died 3, yes three, times yesterday! I even sent a tweet out publicly to samsung and verizon about this and all I've been doing is chatting with samsung mobile support over twitter direct messages.
    I've noticed that my battery will also go from 20% and then turn off. And when I check battery usages, Android OS is running at close to 20%. This has significantly become worse since Verizon sent out an update just a couple weeks ago. I'll post up some of my battery usages soon.
    What should I do?
    07-29-2015 11:40 PM
  2. Gunny94's Avatar
    Its just the discharge are annoying. If you pay attention to Black Fridays you can get the Note 4 battery for 12$ from Samsung
    07-30-2015 03:58 AM
  3. mountainbikermark's Avatar
    Have any of you tried a cache partition wipe or running in safe mode for a bit? If there's residual junk, like a Windows machine can act like, it could cause it and if there's a rogue app, safe mode will determine if that.
    They are both much faster and easier (and cheaper) than a total reset or new battery. We're stuck with lollipop and Android fragmentation for a bit longer it seems so we've got to figure this stuff out ourselves. No guarantee that M will fix the battery life problems either because we'll still be stuck with fragmentation of aftermarket stuff.
    Support Our Troops !!!
    Beast Mode 4
    07-30-2015 03:30 PM
  4. TechNut79's Avatar
    Amazon has a replacement battery for $14.11 shipped, if you're a Prime member. I just picked one up.
    07-30-2015 03:59 PM
  5. Gozadaman's Avatar
    I did a religious reset of the cache partition practically once a month on lollipop. Safe mode results in a not so smartphone and I like the device doing all the goodies it can do. Avg battery life is now 30+ hours this week. Next week I'll be down to something crazy again no doubt. Thanks for the advice though.
    07-30-2015 04:54 PM
  6. NinJoeAssassin's Avatar
    So I stopped using the fast charging while charging my phone. Since then it has greatly improved my battery life. I'll be down to about 25% battery in like 13-14 hours now. For instance, today I unplugged my phone from the charger at around 8 am this morning...It's 9 pm now and I'm at 27% battery. And I wad on the internet a lot today.
    Gozadaman likes this.
    07-30-2015 11:52 PM
  7. Gozadaman's Avatar
    Surprisingly, my stellar battery life also came after disabling fast charging :S I've no need for the fast charge, leaving my phone like most, on charge overnight. Easy enough to toggle fast charge on should I need it.
    07-31-2015 03:21 AM
  8. Gozadaman's Avatar
    And today this... Wtf?!
    Attached Thumbnails Battery flat instantly from 20+%-screenshot_2015-08-12-10-43-58.jpg
    08-12-2015 05:44 AM
33 12
  1. Severe Battery drain with everything disabled
    By Connort226 in forum Samsung Galaxy S4
    Last Post: 07-30-2015, 06:23 PM
  2. Display Images via Chromecast from Afar
    By ericwilborn in forum Google Chromecast
    Last Post: 07-20-2015, 02:27 PM
  3. Replies: 3
    Last Post: 07-19-2015, 06:18 PM
  4. aloha from hawaii
    By ducatirider in forum New to the Forums? Introduce Yourself Here!
    Last Post: 07-19-2015, 03:00 AM
  5. I want to back up photos from my S6 to my computer.
    Last Post: 07-17-2015, 12:21 AM
