First off, I'm using a non rooted Galaxy Note 4. I'd like to use a controller to play some emulators on it, preferably one with a clip and does not require a root. So far i've tried the Moga pocket and the moga power pro. With the moga pocket, it worked fantastic for a solid 2 hours and then literally never again. The damn thing never reconnected to my phone after the initial play test.
The moga power pro also works fantastic with no connection problems at all. The problem? Every single emulator shares the same problem in that it only reads 1 input at a time. This makes it impossible to play platformers. I cannot jump, run and move at the same time in any mario game. Its horrible. Another downside is, this version has a built in HID mode which is great, but it prevents the VK from moga universal driver and moga vk apps from customizing the buttons. So basically even if i got the input problems sorted out, i wouldnt be able to custom map anything and since it doesnt read the triggers or right analog in the HID built in mode, im SOL with this controller as well.
SO... does anyone have any suggestions with the moga power pro? Maybe i'm missing something? Or better yet can anyone take me away from these ******* garbage moga products and point me towards a controller that works?? I'd greatly appreciate it.
