1. AC Question's Avatar
    Can I use a Samsung flip phone charger to charge my Note 4. Forgot my charger and need to power up...
    07-27-2015 09:39 PM
  2. STARGATE's Avatar
    If it's a micro USB, yes you can, it'll probably take longer to charge though.
    07-27-2015 10:06 PM
  3. Rukbat's Avatar
    Look at the label (you'll probably need a magnifying glass) and find the Output line.
    It has to be 5 Volts (anything up to about 5.2 is okay - below 4.9 isn't). It should have a capacity of at least 700mA if you want the phone to charge while you're still alive. (Anything from there up is fine - I charge phoned from a 30 Amp supply [that's 30,000mA] all the time, the phone draws what it needs.)
    STARGATE likes this.
    07-28-2015 04:35 PM
  1. Replies: 2
    Last Post: 07-28-2015, 04:49 PM
  2. How can I root my Samsung Galazy S3 Verizon phone?
    Last Post: 07-28-2015, 04:38 PM
  3. Why is my wifi slow on only my LG phones but works fine on any other phone?
    By Erkhem Unenbat in forum General Help and How To
    Last Post: 07-28-2015, 04:36 PM
  4. Replies: 1
    Last Post: 07-27-2015, 10:11 PM
  5. Replies: 1
    Last Post: 07-27-2015, 10:08 PM
