1. KahneFan's Avatar
    I don't tend to let my battery drain below 30/40% without plugging in. However, I happened to be away from a power source for a while yesterday. Then, when I my phone got to 15%, I received the low battery warning and thought I better get to some power in the next 30 minutes or so. I looked down 10 seconds or so after the warning and my phone was dead. The iOS user I was with happened to have a micro USB, so I plugged in. When my screen finally displayed something, it read 0%. Why did I go from 15% to 0% in 10 seconds? That's not cool.
    07-30-2015 02:18 PM
  2. KahneFan's Avatar
    HEY! Use the search function! http://forums.androidcentral.com/sam...ntly-20-a.html
    Sorry about that.
    07-30-2015 02:20 PM
  3. goin_nil's Avatar
    Sorry about that.
    Excellent suggestion to yourself! :-)
    Was your battery wobbly?
    07-30-2015 03:01 PM
  4. mountainbikermark's Avatar
    If it's been a long time, if ever, since you rebooted your phone the calibration could be off. The meter might state 20% when it's actually 2%. Also try remove the battery and rub its and the phones contacts with a pencil eraser. It was a must do on my older phones.
    Support Our Troops !!!
    Beast Mode 4
    07-30-2015 03:33 PM
  5. KahneFan's Avatar
    I did see that suggestion, but no, no wobble.
    Beast Mode 4
    I reboot probably weekly-ish, monthly at minimum. I will try cleaning the contacts. Thanks.
    07-31-2015 09:53 AM
  1. Replies: 4
    Last Post: 12-14-2015, 10:03 PM
  2. Can I turn off mms on my LG G4 and run sms only?
    By AC Question in forum LG G4
    Last Post: 08-03-2015, 01:08 PM
  3. Widebrowdroid pops up with warnings and requests money
    Last Post: 07-30-2015, 01:47 PM
