01-25-2016 06:48 PM
153 1234 ...
tools
  1. jreuschl's Avatar
    Don't see anything related to RAW in the camera software.
    08-03-2015 06:55 PM
  2. Nakrohtap's Avatar
    Well that's new...grid lines on the dialer:
    That was included in the last update a few weeks ago.
    Sent from my SM-N910V using Tapatalk
    08-03-2015 07:00 PM
  3. Mannikon's Avatar
    If the update allows RAW saving or manual camera options, you won't see that in the stock camera app. There is an app called Manual Camera Compatibility Test and if you run that and it reports manual options available you have to use a third party camera app to take advantage of the manual options.
    08-03-2015 07:12 PM
  4. slackerjack's Avatar
    Nope, but that wasn't in the Galaxy S6/either so wasn't really expecting it. Hadn't played around with Google Camera through...maybe there's support in hardware. Not the photophile guy though, so I'm probably not the right one to ask...you want to talk games, I'm your guy all day long!
    berryabusr88 likes this.
    08-03-2015 07:52 PM
  5. jreuschl's Avatar
    Speed does seem better in this update.. hopefully battery life, also. I'm doing a factory reset anyway after the major update.
    Oscar Maradiaga likes this.
    08-03-2015 08:59 PM
  6. PookiePrancer's Avatar
    Takes about three seconds for my last picture taken to open from the camera. Faster for me.
    indysteve9 likes this.
    08-03-2015 09:15 PM
  7. MrMLK's Avatar
    Just updated..finally! Lag free. Except the picture lag after taking a pic, but its to be expected with an sd card (from my experience )
    I don't think that has anything to do with the SD card. I keep my photos on the internal storage, and I still get the lag.
    08-03-2015 09:22 PM
  8. godzillinois's Avatar
    Any findings on battery life yet?
    08-03-2015 10:04 PM
  9. DWR_31's Avatar
    Check the other thread. Dude has battery screen shots.
    LG G2
    GSIII
    Galaxy Note 4
    (The Sprint Lover)
    08-03-2015 10:57 PM
  10. DWR_31's Avatar
    Wireless charging isn't a popup anymore. It's a Toast Notification.
    Plus it doesn't stay in the Status Bar or Notifications Pull down.
    LG G2
    GSIII
    Galaxy Note 4
    (The Sprint Lover)
    Attached Thumbnails 5.1.1 Sprint OTA for Note 4 (not edge)- "stuff" and Performance Observations-604514868.jpg
    08-03-2015 11:07 PM
  11. louway02's Avatar
    Just got the update for my Note 4, however, my battery life went from 75% to 46% in 40 minutes. Have anyone else experienced this to? If so, how did you correct it?
    08-03-2015 11:35 PM
  12. Rometheus's Avatar
    All I have ever done is unchecked Connection Optimizer, clicked on Power Saving Mode, put brightness down to 70%. Just took another screenshot of my battery usage. For my battery is exceptional and I have been on my phone damn near all day to see how my battery is. Take notice of the other screen shots I posted and also how long I have been running on my battery since last charge.
    ~Blessed From My Note 4~
    samwifi and dbarnes2270 like this.
    08-03-2015 11:38 PM
  13. louway02's Avatar
    I will try that. Thanks
    08-03-2015 11:45 PM
  14. Southernn's Avatar
    Well seems to working good that is awesome now since I am on Verizon I only have 2 more weeks to wait for my carrier to push them out to us.
    08-04-2015 12:08 AM
  15. srsgonu's Avatar
    Where to uncheck connection optimizer?
    08-04-2015 12:12 AM
  16. Rometheus's Avatar
    Settings>More Networks>Mobile Networks
    08-04-2015 01:29 AM
  17. Tony tata's Avatar
    So after about an hour fiddling with 5.1.1 all the sudden I got a pop up saying the device needed to be restarted. And had a 25 second count down. Anybody else get that? I wasn't in an app or anything just my home screen
    08-04-2015 05:16 AM
  18. harriskathym's Avatar
    Has anyone else noticed that a flashing blue light is in constantly on. At first I thought it was just when it was charging, but have had it off the charger for an hour know and it is still doing it. I even turned off all LED Notifications.
    08-04-2015 07:41 AM
  19. RinoFxx's Avatar
    How is the battery?
    Inviato dal mio SM-N910F utilizzando Tapatalk
    08-04-2015 07:42 AM
  20. ayofiggy's Avatar
    I received that a few hours after i updated idk why but after i did restart it my phone has been working better
    08-04-2015 08:06 AM
  21. zaydabarber's Avatar
    Do a master reset after update to get all bugs out
    AT&T note 4 & gear 2 & gear s
    08-04-2015 09:46 AM
  22. dd_terry's Avatar
    Yes. Mine rebooted on its own also. I was not using it when it rebooted so I did not notice a countdown.
    08-04-2015 09:48 AM
  23. PookiePrancer's Avatar
    Yup. I got that as well. Nothing since.
    08-04-2015 10:08 AM
  24. berryabusr88's Avatar
    No raw support. Are you surprised? The note edge and note 4 customers are getting $hit on by samsung. All they are worried about is the new copy apple adventure.
    08-04-2015 10:56 AM
  25. jorgerios21's Avatar
    I think WiFi timer is gone!!!
    08-04-2015 11:12 AM
153 1234 ...
  1. Replies: 2
    Last Post: 03-05-2016, 06:06 AM
  2. Why can I no longer send and/or receive email?
    Last Post: 08-03-2015, 09:12 AM
  3. Install my apps and sync data to iPhone
    Last Post: 08-03-2015, 08:16 AM
