1. AC Question's Avatar
    My Note 4 is currently displaying limited apps and settings in a blk and white mode. I can access contacts and the phone works to send and receive calls.
    I have been told the device has gone into survival mode- possibly because of the large quantity of high resolution pictures I had been taking.
    Plz hold the should have had an SD card comments. I just came over from Apple, and that is not an option at this point.
    THERE IS NOT AN OPTION to turn opp Ultra Power save anywhere. When I swipe down I am only giving the Settings option and when opened displays the following options:
    Wi-Fi
    Bluetooth
    Airplane
    Mobile networks
    Sound
    Display- brightness is the only option.
    I would prefer not to do a factory reset if there is another way.
    THank you!!
    08-05-2015 05:27 PM
  1. Note 3 ir blaster doesn't work
    By recDNA in forum Ask a Question
    Last Post: 08-08-2015, 12:14 PM
  2. Links not working for MMS in stock messaging app
    By ponytd in forum Samsung Galaxy Note 4
    Last Post: 08-06-2015, 10:53 AM
  3. Highscreen Alpha R Why am I unable to select an option in recovery mode?
    Last Post: 08-05-2015, 05:07 PM
  4. FM Chip in Samsung S5
    Last Post: 08-05-2015, 04:39 PM
  5. Replies: 0
    Last Post: 08-05-2015, 04:38 PM
