Originally Posted by
Live_4_2_day My questions the same, but also, Will the SD card hurt, change, or destroy anything when I insert it?
It shouldn't damage anything when you insert the card into the phone. However when you remove the card from the phone, you need to safely unmount it first. To unmount it, go to Settings > Storage and click on Unmount SD Card anytime you want to remove the card. When you place the SD back in the phone, the phone should automatically mount the card, but if it doesn't, go back to Settings > Storage and click on Mount SD card.
