2 Attachment(s)
Re: I hate waking up to Note 4 poor battery life
It happened again! lol!
Idk what the deal is here. Factory resetting isn't an option because I have around 200 apps installed and going through them all over again and setting them up is going to be a pain. I installed Greenify it seems to have helped but I guess not last night. I can maybe pinpoint this - I turned the 'keep wifi awake signal' to 'only when plugged in.' idk, something is really messing with my phone and I wish I knew what it was :-(. does anyone know any good wakelock detector apps that are easy to use and manage? I tried to use this one app a while ago but it was very convoluted so I just gave up... I am subscribing to this thread so I'll see your guys' replies... hopefully this gets fixed soon as hm, waking up turning the power button on does nothing - Oh yeah cuz my phone is dead LOL, thank goodness for quick charge, I gtg in about 20 minutes!
Other than greenify what else have you done?
Are you rooted with custom recovery? Sounds like you are. If so then reboot and wipe dalvic cache and cache. If not, reboot and wipe cache. These suggestions were given before but you haven't noted that you have done it so...
Also, how is Google Now set up? Do you have voice detection set to always listen?
Lastly... There's arguably nothing wrong with leaving the phone on the charger overnight... Just saying.. Sure sure, keeping the battery at max for prolonged periods can be detrimental but so is frequent deep cycling and at the end of the day we are talking about a replaceable battery that one can buy for $12.50 (amazon, anker 2 pack with a charger for $25).
Sent from my SM-P900 using Tapatalk
"Android System" is pulling quite a lot. That can be many things, but often boils down to an SD card with a bad file on it that the system is trying to index and failing, then it repeats. If you have an SD card on board, pull it and leave it off for a night and see if that helps out.
Also, as others have said (and I realize this does not solve your actual battery drain), there is no harm done in leaving a Note 4 on the charger overnight. Yes, it will shorten the life of your battery by a tiny amount, maybe. But for $20 you can get a replacement battery. Use the device in the way that wuits your needs the best, and don't worry about babying the battery on a unit where it can be swapped out.
Originally Posted by
ericmazariegos as to the post above regarding the SD card... i might try that, but doing so requires me turning my phone on and off, which may fix the issue in and of itself, which would lead me to belive the problem lied with the memory card instead of something on the phone internally.
Fair enough. Before removing the SD card, then, I'd try restarting. That way, if the problem persists, you know that whatever the problem is, it is surviving reboots. Then if the SD card removal works, you know the problem. If the SD card removal does not work, then you know it's something that survives reboots and is not the SD card.
(I've had an SD card since the first day I had this phone and never thought it could contribute to poor battery life, but that chance seems so minimal so I'm not gonna do it just yet
SD cards go bad, and files get corrupted for other reasons. I'm not saying it *is* the problem, only that seeing that task so high often turns out to be a bad file on an SD card (or, less often, a bad SD card) when it comes up here as an issue.
However, it's a perfectly reasonable approach to isolate everything else first. Especially if you have a bunch of apps moved to the SD card or something, because removing that SD card will cause many other problems in that case.
As far as the charging overnight part is concerned yeah I get it, but our comments in that regard are purely based upon the title of this thread nothing more. Fact of the matter is leaving off charger overnight is the BEST way to determine standby drain, especially on wifi.
Despite not having root you can still clear cache in stock recovery and that may resolve your issue. I've observed times when updates to Google Services or other apps have caused issues and a reboot or clear cache will resolve that. Your top 4 battery usage indicators are Google/Android related so its possible things will clear up with a reboot/cache clear. IMO it's unimportant to pinpoint exactly what update caused a wakelock that's resolved by a reboot or cache clear.
Video guide i found on youtube:
https://www.youtube.com/watch?v=s4Dq4jyefwM
Also, please note that some battery monitoring software will place wakelocks/alarms on the system so that the monitoring can take place. It is generally not recommended to keep them running all the time, just use them to figure out where your drain is and once you're done then uninstall them.
