1. shlomoreuven's Avatar
    Note 4 Battery drain-uploadfromtaptalk1439315456847.jpgNote 4 Battery drain-uploadfromtaptalk1439315470869.jpgNote 4 Battery drain-uploadfromtaptalk1439315489679.jpgNote 4 Battery drain-uploadfromtaptalk1439315502108.jpgNote 4 Battery drain-uploadfromtaptalk1439315516120.jpgClick image for larger version.
    Please help me to fix the battery draining
    Photos attachments
    Sent from my SM-N910F using Tapatalk
    AlexMarie15 likes this.
    08-11-2015 01:53 PM
  2. mmakoto's Avatar
    I've had at least 4-5 device resets on my note 4 ever since lollipop upgrade, tmobile variant. Battery would drain over 50% even when i had gps, bt, wifi shut off during sleep hours. Nothing i can do except to reset the device.
    Sent from my SM-N910T using Tapatalk
    08-12-2015 09:47 AM
  3. goin_nil's Avatar
    Not that this helps you but one clue is that something has kept your phone awake the entire time, see below. That's what's killing the battery.
    Determine what that is and problem solved.
    Sorry for being vague but one step at a time.
    Try installing Watchdog and see if something is keeping the CPU running at a high rate.
    Have you installed any new apps or updated apps since this just started happening? Could be a bad app or bad app update.
    08-12-2015 10:25 AM
  4. goin_nil's Avatar
    From their screenshots, it looks to be 3 apps. Android battery stats in the phone's Settings, Better Battery Stats, and also GSam.
    08-12-2015 11:57 PM
  1. LG G4 Battery and Cradle to trade for Leather Back
    By redlinecoatings in forum Marketplace Archive
    Last Post: 09-28-2015, 05:39 PM
  2. I hate waking up to Note 4 poor battery life
    By ericmazariegos in forum Samsung Galaxy Note 4
    Last Post: 08-20-2015, 05:33 PM
  3. Why doesn't my battery charge work sometimes?
    By Amna Akhtar in forum Samsung Galaxy Note 8.0 Tablet
    Last Post: 08-14-2015, 12:16 AM
  4. Replies: 2
    Last Post: 08-12-2015, 08:28 AM
  5. Replies: 0
    Last Post: 08-11-2015, 01:12 PM
