1. AC Question's Avatar
    I had issues with my new note 4 edge which I got about 3 months ago for overseas. So I did not have the option of getting a new one....The camera literary took about 1- 2 minutes to get the focus right and sometimes more. I tried all methods like clearing cache, changing the settings, having just auto mode, HDR off..etc and non seems to work. Then finally, I just tapped the middle screen and yay... it worked. As soon as u switch on the camera on ur note 4 edge, trying tapping the middle of the screen couple of times and the focus comes almost instantly in seconds!
    08-12-2015 12:07 PM
  2. adock22096's Avatar
    It could just be a bad sensor. My first note 4 had a bad sensor too. It would focus if you shook the phone. That one was replaced.
    The one I have now is a little better bit not perfect. I'll probably get it replaced sooner or later.
    08-12-2015 07:59 PM
  1. How do I add permissions for Whatsapp to use my camera?
    By AC Question in forum WhatsApp for Android
    Last Post: 10-22-2015, 03:53 PM
  2. Can I get some help with a Camera problem?
    Last Post: 08-12-2015, 12:04 PM
  3. Note 4 - Textra - Anyone else...
    By Kjthomas0724 in forum Samsung Galaxy Note 4
    Last Post: 08-12-2015, 11:29 AM
  4. Best Gamepad Controller for Note 3?
    By xLightning in forum Samsung Galaxy Note 3
    Last Post: 08-12-2015, 11:22 AM
