1. chuco35's Avatar
    I've got an old Note 4, with a battery pushing 2 years. I've decided to not buy the Note 5, but instead keep my perfectly good Note 4 until the Note 6 comes out next year. My battery life is not the best, and I am wondering whether it might be time for a new fresh battery to use for the next year. How often is it suggested you replace your battery on the Note 4?
    08-13-2015 09:39 AM
  2. jordyd's Avatar
    An old note 4 with a battery pushing 2 years?
    Sent from my Galaxy Note 4
    Christine Aflak likes this.
    08-13-2015 09:52 AM
  3. Maggie Pantsvanilla's Avatar
    The Note 4 hasnt even been around a year.
    08-13-2015 10:21 AM
  4. Telespielstube's Avatar
    Maybe a typo
    Sent from my iPhone 6 Plus using Tapatalk
    08-13-2015 01:32 PM
  5. QuietJedi's Avatar
    A typo. Anywho, now's the time to get a Note 4.
    08-13-2015 02:40 PM
  6. chuco35's Avatar
    Yep a typo. My battery has been in use for 10 months.
    08-14-2015 05:13 PM
  7. Rmedy21's Avatar
    If you like try getting a extended battery...
    Quote The Note 4 Never More😤
    08-14-2015 05:56 PM
  8. atakin77's Avatar
    Just get a new one on Amazon or eBay. They are very inexpensive and you could use the older one as a backup if you need to swap quickly later in the day if you need to.
    chuco35 likes this.
    08-15-2015 07:05 AM
  9. goin_nil's Avatar
    You could try this test...
    Pull the battery out.
    Place it flat on a table.
    Does it wobble at all when you alternate pressing back and forth on both long sides?
    Turn it over and try the same thing. Any wobble?
    If it wobbles at all, look closely for a bulge. If you see one, there is a blown cell. Time to replace the battery.
    I got these $25 batteries + wall charger and they work very well:
    [NFC/Google Wallet Capable] Anker 2 x 3220mAh Li-ion Batteries
    http://www.amazon.com/dp/B00Q4NQQA0/...cUvbUpU4610846
    If the battery sits flat with no wobble, the battery is likely fine (no blown cell) but you can replace it and see if that solves the issue.
    Good luck!
    08-16-2015 06:40 AM
  1. Verizon updates the note 4 for stagefright security fix
    By pstellato73 in forum Samsung Galaxy Note 4
    Last Post: 08-14-2015, 12:26 AM
  2. Gallery is sucking battery but is not on????
    By OnlyGirlofFive in forum Batteries
    Last Post: 08-13-2015, 09:32 AM
  3. Replies: 1
    Last Post: 08-13-2015, 09:22 AM
  4. Gallery is sucking battery but is not on????
    Last Post: 08-13-2015, 09:08 AM
  5. Annoying Snap Dragon AD at the bottom of page
    By SlappyMcgee in forum The Android Central Lounge
    Last Post: 08-13-2015, 08:17 AM
