1. Note4Droid's Avatar
    Hi,
    I bought this MHL 2.0 cable on amazon to watch videos from my phone on my tv, but the micro USB male end given does not fit into my note 4. I included a picture below (left is MHL cable, right is Note 4 charging cable). If anyone could guide me to an adaptor or the right cable I could buy I would appreciate it!
    08-17-2015 12:23 PM
  2. pduffer's Avatar
    Are you certain that is supposed to be micro USB and not micro HDMI?
    Sent from my SM-N910V using Tapatalk
    08-17-2015 12:39 PM
  3. Rukbat's Avatar
    I wouldn't even bother. The Note 4 will run Chromecast, so buy the dongle, install the app and stop worrying about tripping over wires. I use it on my Note 3, my grandsons run it on their devices, and it works nicely. It's usually on sale somewhere for about $25. (Best Buy, in the US, currently has it for $30. Walmart has it for about a dollar less.)
    Note4Droid likes this.
    08-17-2015 12:47 PM
  4. tituswife's Avatar
    Hi,
    We don't have a smart TV, or good WiFi (for casting). This cable is cheap, and works great.
    http://www.amazon.com/gp/aw/d/B00MY0...cUvbUpU4613772
    08-17-2015 01:14 PM
  5. IAmSixNine's Avatar
    Not compatible with your device. In the description it says,
    Compatible ONLY to Samsung 11-Pin micro USB interface device, including: Samsung Galaxy S3/S4/S5/Note 2/Note 3, Galaxy Tab 3 8.0, Tab 3 10.1, Note 8, Note Pro.
    You have the Note 4 which is not on the list.
    08-17-2015 02:45 PM
  6. Note4Droid's Avatar
    Thank you! I will skip the wires and go with a Chromecast
    08-17-2015 04:33 PM
  7. tituswife's Avatar
    Are you speaking to me? The device does work on my Note 4.
    08-17-2015 08:45 PM
  8. IAmSixNine's Avatar
    Guess they need to update their description.
    08-18-2015 07:22 AM
  1. switching to iPhone from nexus 6?!?!?!
    By Isaac3 in forum Google Nexus 6
    Last Post: 11-15-2015, 09:58 AM
  2. T-Mobile note 3 preowned certified
    By Linh321 in forum T-Mobile Samsung Galaxy Note 3
    Last Post: 09-11-2015, 03:44 AM
  3. do you need help with note 4 battery life
    By Peter Searle in forum Samsung Galaxy Note 4
    Last Post: 08-18-2015, 03:09 PM
  4. Should i buy g4, need help ?
    Last Post: 08-17-2015, 12:24 PM
  5. Note 5 in Sprint dual band / tri band?
    By mrhankey184 in forum Samsung Galaxy Note 5
    Last Post: 08-17-2015, 11:53 AM
