H3aTeRzz
Same issue on Unlocked TMobile Note 4 910T3 5.1.1
Just disabled Smart Lock....seeing if that might help.
"So far," since disabling smart lock, no issues.
So, I'll weigh in. I too have Sprint. I too have fingerprint scanner enabled and I too have issues with random "computer burps." IT'S. ANNOYING.That said, WHY? This seems to be a Sprint device issue (mainly), which tells me something they overlaid onto the phone is jacking it up ( a brief google search showed no results for Verizon/ATT and only a couple mentions of T-Mo) OR they bought the "f-class" versions of these phones at a discount from Samsung. And these errors are SOOOOOOOO random. Things like: "SIM card not inserted" but a replacement of SIM card and two factory resets haven't gotten rid of this. Possible solution: remove/replace SIM appears to make it stop for a while (although could be coincidence) but it just. keeps. coming. BACK. Random things like the phone "burping" right in the middle of swiping a fingerprint, wherein after a misswiped finger or two, the screen a) showsno match, b) goes blank except for the background and then c) either locks/resets/turns off or (even WORSE) UNLOCKS! This same thing happens sometimes while the screen has been appropriately unlocked and any random app is on the screen (or from the desktop, as I said, RANDOM). I currently use Nova, but TouchWiz did it as well. Sad face. Anyone figure out anything with this? I had a GS3 and in 3 years of ownership it NEVER EVER EVER had any problems like this. I understand extra complexity, but come on... This phone is unfortunately past the take back date to BIG BOX and Sprint says it's a Samsung issue and Samsung says it's a Sprint issue and either way- my phone doesn't work. Grrrr...
Hi, I'm having exactly the same problem. Just been locked out of my own phone! It won't show me the fingerprint scan option but instead jumps straight into the emergency password screen which it doesn't recognise although it's the right one! It's so annoying. I'm in the UK on Three network. How did you do the factory reset? how can i do it if i can't even access the settings on my phone?
Thank you,
Wellington
How did you reset your note4 if you couldn't unlock your device?!
I'm from South Africa, solved my issues by wiping the cache partition and then doing the factory reset. Before anything, do remember to back all yor date up on cloud or other storage especially date stored on the phone. Switch the phone off, switch it back on in recovery mode by holding the power, home and volume up button. Once there use the volume rockers to navigate the list down to wiping the cache, use the lock button to select the desired option. On the bottom of the screen it'll tell you once the wiping has been done. Thereafter navigate down to factory reset, select yest and your phone will take 3-4mins and will prompt you to reboot. The phone will be like brand new but with the android version it had installed. I did this and all my issues have been resolved
Me too
Try this one. Make blue tooth in car radio a smart lock trusted device, set ur phone to pin lock screen, while blue tooth on, let phone time out to the lock screen, u now only have a swipe screen, then either pull down notification window/shut off Bluetooth or turn your car engine off and in several seconds the lock screen panel re appears and all is normal. This is a conflict between smart lock and the phones lock screen function. A bug in the software build.
Changing the lock screen security from FingerPrint to Pattern lock Fixed the issues for me.
