Factory reset plus clearing cache did nothing for me, had to disable fingerprint locking.Anyone tried full factory reset?
I had to disable it
Is there a special way to disable the fingerprint scanner, besides just not using it in security options?
Just change your unlock method to Pin, Swipe or none....that's all.
I set none...wallaaaa its still frezzing.
Some thing happens to me. I have factory reset and cleared cache 3 times with no fix. This is a problem. Telling us to simply use another form of logging in (pin or password) is not a solution. I bought this phone with the features it came with so that I can use the features. I want to use the fingerprint scanner. Fix it.
My wife and I both have Note 4s. This problem happens on both of our phones but much more on hers. She tried a full reset but it did nothing to fix the issue.Anyone tried full factory reset?
