1. AC Question's Avatar
    I have read all of the details here regarding the Verizon Samsung Note 4 being a factory unlock. Verizon is killing me with their billing and add ons. Cost me more per month than my Car not with 2 phones.
    So if I were to pull out the Verizon Sim card and install the Straight Talk Sim Card my
    Verizon Note 4 should operated as normal. It has both GSM & the CDMA radios installed . I was told by the T-Mobile people that it would work only for talk and text, but that it would not work with data.
    From what I read here it should not make a difference. Where I live is remote and only Sprint & Verizon have good connections, ATT & T-Mobile are spotty with giant areas of no coverage. The Straight Talk is supposed to work off of both GSM & CDMA networks.
    Could you clear this up for me.
    09-01-2015 11:51 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Go to this website to check your phone's compatibility: https://forums.androidcentral.com/e?...token=PX4xvXMr
    nahoku likes this.
    09-01-2015 12:36 PM
  3. Z3ljk0's Avatar
    straightalk has an sim that you can use on Verizon towers,itrs an straightalk sim but on Verizon towers,
    my wife has an s4 and running it like that getting 4g lte with great connection
    h**p://smartphonematters.com/straight-talk-wireless-now-supports-verizons-4g-lte-network/
    nahoku likes this.
    09-01-2015 01:14 PM
  1. need help......verizon change of ownership
    By morbidking in forum Verizon
    Last Post: 09-05-2015, 03:57 AM
  2. no raw support our Samsung pay on Verizon??
    By Richard Servello in forum Samsung Galaxy S6 edge
    Last Post: 09-04-2015, 03:25 PM
  3. Verizon: Watching your phone in Real Time/Bad Battery
    By LocationDudeNYC in forum Samsung Galaxy S6 edge+
    Last Post: 09-04-2015, 02:46 PM
  4. Why does my Samsung /Sprint think I'm in Texas?
    By AC Question in forum Samsung Galaxy S6 edge+
    Last Post: 09-01-2015, 01:06 PM
  5. How can I get my Samsung Galaxy to turn on properly?
    By AC Question in forum Samsung Galaxy A3
    Last Post: 09-01-2015, 12:47 PM
