Is it normal for battery to be at 100% at 6am and by 10am battery is at 70% with minimal usage?
Screen brightness seems to be the biggest factor for my N4 battery life. If I keep it around %50 I can get a whole day with moderate use. I start my day at 6am and end my day with %35 around 10 pm.
I am in the process of making my Note 4 self aware.
I think it depends on alot of things : wifi, bluetooth, streaming, signal strength, brightness etc ..
Try using ur phone till it reaches 10% then check ur SOT if it is something near 4 u r safe , if not then install one of the wakelock apps and see what's going on.
Those wakelock apps are worthless unless you're rooted. It shows you nothing more than what the stock battery stats show.
