1. Macsen191's Avatar
    Is it normal for battery to be at 100% at 6am and by 10am battery is at 70% with minimal usage?
    09-02-2015 10:53 AM
  2. NotAnAppleGuy's Avatar
    How old is that battery?
    Posted Via Galaxy Note Edge. Yea, the phone is perfect...
    09-02-2015 11:12 AM
  3. Macsen191's Avatar
    The battery is about a year.
    09-02-2015 11:26 AM
  4. Tahir Ahmed1's Avatar
    I think it depends on alot of things : wifi, bluetooth, streaming, signal strength, brightness etc ..
    Try using ur phone till it reaches 10% then check ur SOT if it is something near 4 u r safe , if not then install one of the wakelock apps and see what's going on.
    09-02-2015 12:07 PM
  5. bobxxz's Avatar
    Since it's been a year, you should still be getting around 4 hours SOT. I just had my battery replaced and I'm getting my 5 hour ish SOT back. My old battery now last me only 3-4 hours SOT depending on what I do.
    09-02-2015 01:06 PM
  6. fragologist's Avatar
    Screen brightness seems to be the biggest factor for my N4 battery life. If I keep it around %50 I can get a whole day with moderate use. I start my day at 6am and end my day with %35 around 10 pm.
    I am in the process of making my Note 4 self aware.
    09-02-2015 01:26 PM
  7. Tahir Ahmed1's Avatar
    Yeah me too in addition to bad signal
    09-02-2015 02:01 PM
  8. LegalAmerican's Avatar
    Those wakelock apps are worthless unless you're rooted. It shows you nothing more than what the stock battery stats show.
    09-02-2015 02:14 PM
  9. Tahir Ahmed1's Avatar
    I think watchdog lite has alot of amazing features even for unrooted phones.
    09-02-2015 05:03 PM
  1. Galaxy Note Pro 12.2 64GB Tablet $499.99 (wifi model).
    By tarpon6 in forum Samsung Galaxy Note Pro 12.2
    Last Post: 09-10-2015, 09:07 AM
  2. Is there a ''clear view'' case for the Note Edge?
    By AC Question in forum Samsung Galaxy Note Edge
    Last Post: 09-03-2015, 08:56 PM
  3. Caller ID on Incoming Calls??
    By greyserf in forum Moto X (2014)
    Last Post: 09-02-2015, 02:59 PM
  4. Replies: 1
    Last Post: 09-02-2015, 02:21 PM
  5. My phone screen doesn't turn on but my the touch works fine, what's wrong?
    Last Post: 09-02-2015, 02:13 PM
