1. AC Question's Avatar
    I just updated to 5.1.1 note 4 and rooted it and this problem occurred. I already did a factory reset and this problem still occurs. I'll be texting or on the Web and the screen will lag then lock. I already wiped cache.. What may be the problem.. Note 4 sprint 5.1.1
    09-03-2015 07:47 PM
  2. grahamtheman's Avatar
    09-04-2015 10:16 AM
  3. Nitro211K's Avatar
    Hi, this issue is common after the 5.1.1 update, and it seems to be mostly a SPRINT thing. What solved it for me was using Pattern Lock instead of FP scanner to unlock my screen, and I have been Golden since then.
    09-04-2015 11:35 AM
  4. H3aTeRzz's Avatar
    Same here, on Unlocked TMobile, Note 4, running 5.1.1. Love the FP technology, guess I'll have to do without it till a fix is released.
    09-07-2015 12:57 PM
  5. dbgman's Avatar
    turn off smart lock. That is what I found that fixes the lag/lock problem.
    10-07-2015 06:50 PM
  1. Replies: 5
    Last Post: 09-04-2015, 01:07 PM
  2. Can I install apps on my SD card?
    Last Post: 09-03-2015, 07:52 PM
  3. How do I switch OFF the small light at the back of my GALAXY 10.1?
    By Johan Kotze1 in forum Samsung Galaxy Tab 2 10.1
    Last Post: 09-03-2015, 07:00 PM
  4. Replies: 0
    Last Post: 09-03-2015, 06:58 PM
  5. How can I relock my bootloader on moto x 2014 pure edition?
    Last Post: 09-03-2015, 06:55 PM
