1. AC Question's Avatar
    I have a Samsung note 4 that I've been having problems with. It started out where it'd reboot itself then it started to power cycle unless it's plugged into the charger. I called Verizon and the tech talked me through the cache clearing. It didn't help so they sent me out a replacement. That too did the same thing. I assumed it was the battery but was told that it is a software problem. So I go to Verizon and they order me yet another replacement. I'm wondering if the sim card could be bad or what else it could be. It seems weird the replacement would do the same exact thing. The Verizon staff had no explanation for me. Help?
    09-06-2015 10:04 AM
  2. Golfdriver97's Avatar
    Welcome to the forums. If the battery is the same as your original phone try this: pull it out and place it on a smooth flat surface. Try to spin it. If it does, it's bulged in the center and needs to be replaced.
    If the bulge is there, that is what is creating your boot loop. What is happening is the bulge is creating a pivot point (like a seesaw) and is causing intermittent connection to the battery. The cable connection is wired differently, and bypasses this.
    09-06-2015 10:19 AM
  1. Help (hijacked)phone goes dirictly to play store
    By litchie in forum Ask a Question
    Last Post: 09-07-2015, 01:31 PM
  2. How do I send a specific part of a website to share on my Samsung Android?
    Last Post: 09-06-2015, 10:21 AM
  3. Replies: 0
    Last Post: 09-06-2015, 09:56 AM
  4. Why am I unable to view photos in my album?
    By AC Question in forum Sony Xperia P
    Last Post: 09-06-2015, 09:53 AM
  5. Can I take a paragraph from any website and text it to someone?
    Last Post: 09-06-2015, 09:51 AM
