1. aygo1989's Avatar
    Evening guys,
    I set up my brand new note 4 earlier, all was well until I noticed a noise coming from the rear speaker that whistles for 5 seconds then cuts out after any sort of input whenever I press the (backup key or anything on the keypad) Is this normal?
    Thanks
    09-07-2015 06:40 PM
  2. ChemMan's Avatar
    Never heard anything like that from my Note 4.
    09-07-2015 06:48 PM
  3. aygo1989's Avatar
    The worst thing is I know it's there even when I forget about it. Whenever I put my ear to the phones speaker after an operation it's there
    09-07-2015 06:51 PM
  4. Rarry's Avatar
    Sounds faulty, I'd return it. Even if it's minor, or fixable with a reset, there could be something else wrong or about to go wrong.
    09-08-2015 02:25 AM
  5. aygo1989's Avatar
    I read on another forum that this is normal? After any sort of touch (return button mostly) or loud sound, If I place the speaker to my ear straight after I get a 3-5 second buzz and then cuts. Can you guys please check this with your device please, this would be my 3rd Note 4 to go back
    09-08-2015 11:57 AM
  6. Rarry's Avatar
    Wow you're right. If I press return and quickly hold speaker to my ear there's a slight whirring noise for a couple of seconds. It is very quiet though, I'd never have noticed it without the phone speaker to my ear. You must live somewhere very quiet!
    Why did you have the speaker to your ear anyway? You'd be deafened by any real sound from it.
    09-08-2015 02:15 PM
  7. aygo1989's Avatar
    Can you actually hear it buzz and then cut after 3-5 seconds or are you winding me up? If so I'll keep this one for the time being, it does have insurance and it's most definitely the best looking one I've received concerning the gaps.
    Thanks Rarry!
    09-09-2015 04:23 AM
  8. aygo1989's Avatar
    Thinking it's normal now, going to try pop into a phone store over the next few days. I've found it happens constantly when watching a video on youtube with the volume all the way down.
    09-09-2015 04:41 AM
  9. Rarry's Avatar
    Yes, mines the same, a faint buzz when playing YouTube with volume at zero. But it's very quiet, need the phone speaker pressed to my ear to hear it which is something I'd never do normally.
    09-09-2015 08:22 AM
  1. Why is there no sound in top speaker of moto g 3rd gen?
    Last Post: 09-17-2015, 12:25 PM
  2. Replies: 7
    Last Post: 09-14-2015, 05:28 PM
  3. Connection with Bluetooth Speaker keeps Dropping
    By smooth4lyfe in forum ASUS ZenFone 2
    Last Post: 09-07-2015, 05:50 PM
  4. get streaming tv audio from tablet to bose amp/speakers
    Last Post: 09-06-2015, 07:13 AM
  5. Replies: 1
    Last Post: 09-03-2015, 04:58 AM
