Hi guys, I recently bought my new note 4. First 2-3 charges cycles battery was draining quite fast. Read here that its normal for first few. Then now my battery level seems to be plunging a few % every time I reatart my phone. Disabled whatever I could but doesn't seem to be helping. Any ideas, please?
To preserve battery try to disable lots of Google services,also try not having a live weather app. Turn off notifications, ie news apps, turn off location services.
My battery was charged today 9 am it's now 20.38 and I'm in 41%.
Good luck.
That is a great ideas, but it's still not enough as yet. You need to turn some more off in the system app as well. Also some of the pre-install apps need to be off such as "Voice Command" and so on.
By sending this reply, I also have a problem with my NOTE 4 in term of "Gallery app", normally, after you made a photo, then you access to the gallery to view and/or edit that photo straight away on the gallery with "Photo Editor", but I was accidentally uninstall the pre-installed "Photo Editor" Which add-in in Gallery app, then I cannot get it back as it says that Photo Editor is no longer downloadable.
Just an FyI, you shouldn't really uninstall the preinstalled apps. Just disable them in Settings >Application Manager. That way when you need them, you can just enable them again. Sorry, can't help with how to get the photo editor back, unless you do a factory reset again. Takes time, but should get it back I would think. Hope that helps.
I had that issue with the Photo Editor, reset fixed my issue.
Same happens when you lose for example the messaging or Gallery app.
