1. ApolloOKC's Avatar
    Hi! I plan to order an unlocked Galaxy Note 4 N910G. I'm confused about its compatibility with T-Mobile's LTE frequencies. The phone supports the LTE bands 4 (AWS) and 2 (PCS) but it doesn't support the band 12 (which might not a big deal since I will use the phone mostly in the State of Oklahoma where there are no plans for 700MHz deployment according to spectrumdeployment.com). Some users mention that the status icon of this phone will show 4G (which means anything from HSPA to HSPA+, but definitely NOT 4G LTE). So my question is where the truth lie? If both models (T-Mobile's N910T and N910G) both have the same LTE frequencies, other than band 12, why the N910G wouldn't show 4G-LTE? Also I would like to know if I can disable WIFI while I'm using USB tethering or it will stay on all the time.
    09-20-2015 06:45 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! If it supports Bands 2 and 4, it'll get LTE on T-Mobile. I can't be sure about the icons--it might be 3G/4G/4GLTE, or E/H/H+/LTE, or some combination. For what it's worth, my Zenfone 2 says 4G when I have LTE, and H+ when I have HSPA+, so just because it says 4G doesn't mean it's not getting LTE.
    09-20-2015 10:24 PM
  3. ApolloOKC's Avatar
    Thank you for answer! Can anyone confirm please that Wifi can be deactivated during USB tethering?
    09-20-2015 11:20 PM
  1. LTE drops out..
    By Saywhen13 in forum Samsung Galaxy S4
    Last Post: 09-21-2015, 10:59 PM
  2. 6S Edge+ Question about using your own text tone...
    By dennycrane2014 in forum Samsung Galaxy S6
    Last Post: 09-21-2015, 10:14 AM
  3. LTE drops out..
    By Saywhen13 in forum Ask a Question
    Last Post: 09-20-2015, 10:29 PM
  4. About how much would it cost to have an Android screen fixed?
    Last Post: 09-20-2015, 04:42 PM
  5. I got the green bot with a red question mark
    Last Post: 09-20-2015, 10:51 AM
