1. QuynhHao's Avatar
    I'm new to Samsung and I have just bought one on ebay and the seller said it's unlocked but when I insert Tmobile Sim card , it doesn't work at all. Moreover, when I insert the Sim card it does not require unlock code.
    Can any body help me find solution ?
    Thank you.
    09-24-2015 09:37 PM
  2. Kjthomas0724's Avatar
    Thank you.
    Take it to t-mobile and see what they say
    09-25-2015 10:59 AM
  3. drenfree's Avatar
    If the phone is unlocked then it should not ask you for an unlock code. Is the T-Mobile sim active? Do you get any signal
    Sent from my Nexus 6 using Tapatalk
    09-25-2015 11:17 AM
  4. IAmSixNine's Avatar
    we need more info.
    Your telling us when you insert a TMO sim card it doesnt work at all.
    No Power? No service?
    09-25-2015 11:19 AM
  5. QuynhHao's Avatar
    I can't make a phone call. I have just inserted Sim card again and it has "T mobile " at the left corner and then after few seconds it disappeared.
    The phone has full battery
    09-25-2015 08:59 PM
  6. QuynhHao's Avatar
    And the smartphone had Att provider
    09-25-2015 09:01 PM
  7. H3aTeRzz's Avatar
    Quite possibly, you "may" need a replacement sim. Goto your TMOB store and let them help you, they can get you a new sim, and see if that works.
    09-26-2015 07:56 AM
  8. IAmSixNine's Avatar
    you might also want to check and make sure the device is not blacklisted and reported lost/stolen.
    IF it registered for a brief time then went to no signal its quite possible its a blacklisted device.
    H3aTeRzz likes this.
    09-26-2015 01:14 PM
  9. QuynhHao's Avatar
    I have just checked it and it's not in blacklist
    Thank you for your advice, I appreciate that.
    09-26-2015 05:53 PM
  10. Kelly Kearns's Avatar
    An AT&T Note 4 will work on T-Mobile. You might want to go to the T-Mobile store, call customer care or tweet @TMobileHelp and get executive customer service to help you. There might be some settings that need to change on the phone or you might just need a new SIM.
    09-26-2015 06:17 PM
  1. Samsung 12.2 Tablet Limps Along...
    By caseous in forum Samsung Galaxy Tab Pro 12.2
    Last Post: 09-30-2015, 09:45 PM
  2. Left G4 for Note 5..
    By crazyralph90 in forum Samsung Galaxy Note 5
    Last Post: 09-27-2015, 04:14 PM
  3. Galaxy Note 5 activates air bag sensor in car
    By John Oliver1 in forum Samsung Galaxy Note 5
    Last Post: 09-26-2015, 06:17 PM
  4. Left side of Samsung Tab 2 doesn't work...
    Last Post: 09-24-2015, 08:41 PM
  5. Replies: 0
    Last Post: 09-24-2015, 07:43 PM
