1. svargas05's Avatar
    What gives?! It just started doing this about a month ago...
    I've seen plenty others complaining of battery issues but wanted to see if I was the only one experiencing this.
    09-28-2015 04:59 PM
  2. tsells's Avatar
    It's called "time to buy a new battery"! Mine did a similar thing a few weeks ago and haven't had any issues since replacing the battery.
    09-28-2015 05:03 PM
  3. nahoku's Avatar
    I'm pretty sure Samsung warrants the battery for a year. You might want to check on it.
    09-28-2015 10:55 PM
  4. lv2bsilly's Avatar
    Same issue with mine. I took mine into Verizon and told them about the issue, luckily it jumped from 13% to 2% while he was looking up my info. They ordered me a replacement, mine was still under the 1 year mark.
    09-29-2015 04:59 AM
  1. Replies: 0
    Last Post: 09-28-2015, 04:44 PM
  2. ZTE static wallpaper went from clear to blurry. HOW TO FIX?
    Last Post: 09-28-2015, 04:39 PM
  3. How to find a malware app in android
    Last Post: 09-28-2015, 04:21 PM
  4. Need help to make Android Application?
    Last Post: 09-28-2015, 04:19 PM
