1. 420benz's Avatar
    Pressing the two buttons doesn't work anymore. Don't know what setting controls this function. Thanks
    09-30-2015 07:54 AM
  2. sweetypie31's Avatar
    Have you tried swiping your palm across the screen?
    09-30-2015 02:54 PM
  3. Kjthomas0724's Avatar
    That doesn't work most of the time for me
    09-30-2015 03:00 PM
  4. nahoku's Avatar
    You might want to try SAFE MODE to see if the problem is being caused by some app you installed.
    09-30-2015 08:37 PM
  1. Samsung S6 Problems syncing emails via IMAP
    By PaulinSpain in forum Samsung Galaxy S6
    Last Post: 10-30-2015, 03:54 PM
  2. problem on my sd card
    Last Post: 09-30-2015, 05:51 AM
  3. Why is my Android M6 remote battery draining over night?
    Last Post: 09-30-2015, 05:12 AM
  4. How do i reinstall the screen capture mini app?
    Last Post: 09-30-2015, 05:06 AM
  5. Samsung manual hard reset problem
    By Gorakh chaurasia in forum Ask a Question
    Last Post: 09-30-2015, 04:08 AM
