1. andonakis's Avatar
    I have been through several Bluetooth devices. Spend several hundred dollars and I'm having the same issues with all of them. People on the other end cannot hear me very well. Here is my list...Plantronics edge, and voyager. SonySBH80. And Sennheiser VMX 200-11 to name a few. I hear them perfect but always get complains that they cant hear me well. So I'm wondering why? These are top of the line Bluetooth devices. I mainly use it for telephone calls. And they all claim to be the best in voice calls. By the way I have factory reset which i do every so often anyways.
    I appreciate any help.
    10-01-2015 07:57 PM
  2. nahoku's Avatar
    There's a very long thread on Bluetooth HERE in the forum. It mainly deals with music, but could also apply to earpieces. My belief is that the Note 4 BT radio is weak. Coupled to weak BT devices like earpieces, (I own a Plantonics Voyager Pro+), makes matters worse. The only way I can keep a decent connection is "line of sight"... basically I need the phone on the same side as my earpiece. My car bluetooth on the other hand, works great with my phone, so I really don't know what gives.
    10-01-2015 10:46 PM
  3. pcbtmr's Avatar
    I have a Voyager and voyager Pro and both work well with my GN4 in that the phone has to be on the same side as the earpiece. Concerning the OP's situation, I would go to your carrier's store and have them look at it. Having multiple devices exhibit the same behavior points to the phone as the issue and there is no setting that says lower the mic volume. If your phone is still within warranty, may want to pursue a replacement.
    10-02-2015 12:42 PM
  1. backup issues!
    By Laserbutt in forum Samsung Galaxy Note 5
    Last Post: 10-07-2015, 07:49 PM
  2. Are you putting in work with SHealth? Let's see it...
    By kj11 in forum Samsung Galaxy Note 5
    Last Post: 10-05-2015, 02:21 PM
  3. Micro Sim to Nano Sim? Help!
    By TrekkieMonster in forum Nexus 6P
    Last Post: 10-03-2015, 11:06 PM
  4. S6 edge plus wifi issues
    By Blant93 in forum Samsung Galaxy S6 edge+
    Last Post: 10-01-2015, 10:29 PM
  5. Galaxy S5 Texting issues
    Last Post: 10-01-2015, 07:19 PM
