1. pappcam's Avatar
    I received and installed the 5.1.1. update to my Canadian Note 4 last week. Immediately I noticed the battery was draining faster so I bit the bullet and did a factory reset. That has not fixed the battery problem.
    My Bluetooth seems to be the main culprit as it drains the battery constantly even when not connected to a Bluetooth device. I use it to connect to my vehicle so I do not want to have to turn it off and on manually.
    This was never a problem on my S3 running 4.0 to 4.2 or my Note 4 from 4.4 to 5.0.1. Bluetooth never drained the battery on those OS's and I do not want to be told to manually turn it off when I don't need it. I'm hoping someone has or had a similar issue and knows how to fix it.
    Thanks.
    10-06-2015 02:33 PM
  2. pappcam's Avatar
    Anyhoo, after some arduous googling, I found that the Gasbuddy app has been giving some people the same bluetooth wakelock issues I've been having. I uninstalled Gasbuddy a couple of hours ago and the problem is gone.
    Here's the page in case anyone is interested:
    https://code.google.com/p/android/is...sort=&id=87778
    nahoku likes this.
    10-06-2015 11:21 PM
  3. nahoku's Avatar
    Thanks for posting!
    10-07-2015 07:32 AM
  4. mpasadena's Avatar
    I have AT&T Note 4 and it was recently updated to Android 5.1.1, and the battery drain was significantly higher compared to when it was on 5.0.1 with all the same apps.
    Removing Gasbuddy seems to have done the trick from what i can see in the past few hours, i had already tried the "Wipe Cache Partition" before removing the GasBuddy app, Everyone having problems with battery life on a Note 4 with 5.1.1 should remove GasBuddy till the time they fix the issue with their need to keep Bluetooth connection on at all times..
    10-21-2015 03:06 PM
  1. Stand alone and contacts
    By gcopter in forum Samsung Gear S
    Last Post: 10-07-2015, 12:44 AM
  2. HTC sense input stopped and now I can't unlock my phone.
    Last Post: 10-06-2015, 09:41 PM
  3. Replies: 1
    Last Post: 10-06-2015, 09:39 PM
  4. Why can't I send text and email messages?
    Last Post: 10-06-2015, 05:03 PM
  5. How to update Nexus 5 from 5.1 to 6 without data loss and maintain root
    By PrimalYeti in forum Android 6.0 Marshmallow
    Last Post: 10-06-2015, 01:21 PM
