1. Tahir Ahmed1's Avatar
    Hi Experts .. so after all these months of use which apps are draining battery the most in ur opinion?
    Me i think facebook app , tunein radio and google play services.
    10-16-2015 05:21 PM
  2. srkmagnus's Avatar
    Opening system settings - battery will tell you which apps are consuming the most battery life. You can also select the apps from that menu to see more information.
    10-16-2015 05:39 PM
  3. Tahir Ahmed1's Avatar
    Thanks but no , i wanna know in general the biggest battery drainers
    10-16-2015 05:49 PM
  4. muzzy996's Avatar
    As-in a general community consensus?
    Not gonna happen . . . well . . you'll get a bunch of opinions . . . but they'll all be based on distinct personal experiences which isn't going to mean a whole lot if everyone is running different software, which we all are.
    I agree that Facebook is one that ranks high for me, but I'm sure that others will have other apps that rank high for them.
    Personally, this is why I root . . to tame apps . . I'm not a heavy FB user for example, I just troll occasionally so I freeze that sucker when not in use using a Titanium backup widget shortcut on my desktop and it therefore drains ZERO for me when I'm not using it.
    With all of my app taming techniques in play I end up seeing Google's own sync and play services stuff being battery hogs. Whether its location reporting or other services.
    10-16-2015 08:07 PM
  5. kurt p's Avatar
    For me it was messenger and words with friends. I deleted messenger and now I log out of words with friends whenever I'm not playing it. Also had Google music always randomly running in rhe background so I disabled that since I never use it.
    10-17-2015 09:14 AM
  6. Tahir Ahmed1's Avatar
    You 're right- now iam thinking seriously about rooting my phone . Just a question: if i root will i have full control of apps like killing them or stopping them from running in background ?and what is the safest root method? bacause iam afraid of bricking my phone.
    10-17-2015 11:10 AM
  7. muzzy996's Avatar
    The engineer in me never likes to speak in absolutes so full no but you would be able to control things significantly yes. Right off the bat with root one can see more detail in battery usage statistics and wakelock detection using 3rd party applications like wakelock detector and GSAM battery monitor etc. That alone will help isolate things quickly.
    Freezing unwanted applications with Titanium backup (I never uninstall, that's dangerous) can help a lot. Then there's greenify and boot managment applications that will help keep applications from starting up until you fire them up yourself. Greenify is most effective with Xposed framework installed that allows experimental features inside greenify to be turned on. Lastly there's applications like Amplify for Xposed that will allow you to block some wakelocks forcing things to operate at longer frequencies to reduce battery consumption on standby even more.
    I find it an iterative and ongoing process whereby as applications update and my usage changes I'll revisit settings and adjust things. It takes patience, research and observation, otherwise there can be some serious lessons learned. Freezing system applications can impact stability if one's blindly going into Titanium and freezing things without knowing what they're for. There's no one stop guide but there are many posts out there of "safe" apps to freeze. The caveat there is, not everyone uses their devices the same way so what's unnecessary for one person may be a critical thing for someone else.
    Rooting's the reason I went straight for a T-Mobile variant when the Note 4 came out last year. I'm on AT&T, but ended up opening a T-Mobile account, paying full for the phone, cancelling the account and using my AT&T SIM in it.
    I'm not sure what variant you have so I can't say how to root it. Recommend checking XDA's forums. I haven't kept up with development for other variants but last i checked months back there was no permanent root for Verizon and AT&T variants.
    Sent from my SM-P900 using Tapatalk
    Tahir Ahmed1 likes this.
    10-17-2015 12:39 PM
  8. PublicImageLtd's Avatar
    The worst drainer I've ever had and deleted it, is PayPal. It restarted non stop using mega battery life. If I use PayPal I just go to website. Battery savers use lots of power too.
    10-19-2015 09:09 AM
  9. mvinoth's Avatar
    Titanium backup not supported in my mobile.
    Model: vivo y22
    Sent from my vivo Y22 using Tapatalk
    10-19-2015 09:45 AM
  1. AC app version 2.0 thoughts
    By Alex Wetzel in forum General News & Discussion
    Last Post: 11-05-2015, 10:58 AM
  2. What are your favorite apps?
    By SpyglassSally in forum Moto 360 (2015)
    Last Post: 10-22-2015, 06:11 PM
  3. Battery issues all of a sudden
    By saffamagic1986 in forum Ask a Question
    Last Post: 10-21-2015, 10:38 AM
  4. (5.1.1.) Forced Update, Battery DrainGate
    Last Post: 10-16-2015, 05:03 PM
  5. Notification: Restoring Apps - Problem
    By juwster in forum HTC One M8
    Last Post: 10-16-2015, 04:30 PM
