1. lpcs1's Avatar
    I bought my GN4 in December of last year , and the battery life then was absolutely wonderful , I recall times where i didn't have to recharge for 2 days!
    But now it's gone seriously awry .... After a full charge the phone , the battery dies within 6-7 hours on standyby with wifi or LTE , and in 2-2.5 hours playing games, or browsing . Even scarier, when the battery reaches the battery alert threshhold at 15% I usually have less than 2 or 3 minutes to plug it before it turns itself off . Sometimes it even shuts down at 11-12% , turns back on again and shows me that the battery level went back to 0%
    It's just impossible to understand .
    Here are the battery usage logs,
    UNBELIEVABLY Crappy battery life !!   Less than 7 hours on standby with wifi .  Shutting down at 10%-screenshot_2015-10-11-21-59-50.jpgUNBELIEVABLY Crappy battery life !!   Less than 7 hours on standby with wifi .  Shutting down at 10%-screenshot_2015-10-11-22-00-48.jpg
    I'm an average user, not using too many apps , always keeping the device running smoothly and never letting it get too hot . Running Lollipop 5.1.1
    10-18-2015 09:18 AM
  2. Marcin Stachurski's Avatar
    After you updated to 5.0 did you happen to do a system cache wipe? I'd give it a try.
    Attached Thumbnails UNBELIEVABLY Crappy battery life !!   Less than 7 hours on standby with wifi .  Shutting down at 10%-img_20151018_093441_01.jpg
    10-18-2015 09:35 AM
  3. lpcs1's Avatar
    will this delete any of my own data ?
    10-18-2015 09:42 AM
  4. Marcin Stachurski's Avatar
    It shouldn't... You should always backup your data either way.
    10-18-2015 10:26 AM
  5. Karlzweb's Avatar
    Have you looked at the apps consuming the battery?Sometimes a rouge or locked up app can kill a battery. I've has where something is trying to backup to my cloud, or the play store trying to update causing this issue.
    10-18-2015 01:15 PM
  6. odb9014's Avatar
    Yup, time for a new battery. I bought my N4 on Halloween last year so almost a year old. Was having similar issues where mine would say something like 25% and then you look at it a minute later and it's at 1% and then shuts down before you can get the charger connected. I called AT&T and had them ship me a brand-new battery, no questions asked other than what it is or isn't doing. Battery and shipping was free of charge because it is still within the manufacturer's 1 year warranty. I would hope the other carriers would do the same. I also bought a brand-new battery from eBay for $20 shipped. Be VERY careful buying on eBay or Amazon because there are TONS of counterfeit batteries without NFC or even less mAh. I got a genuine factory sealed one.
    Long story short, the new battery fixed my issues. 350ish days with a MINIMUM one charge per day kills the battery fast. Isn't it great that it's not a Note 5 with it's garbage sealed battery?
    hyfurd2112 likes this.
    10-18-2015 01:32 PM
  1. Blue tooth crappy range all of a sudden
    By k2cobras in forum Ask a Question
    Last Post: 10-18-2015, 07:16 PM
  2. Enable PTP Storage Mode on HTC One M8
    Last Post: 10-18-2015, 04:29 PM
  3. Shut a feature off??
    By Lindsay11 in forum Displays
    Last Post: 10-18-2015, 11:38 AM
  4. Does no SIM means that the only way to connect to internet is by WIFI?
    By acsurfer in forum General Help and How To
    Last Post: 10-18-2015, 09:27 AM
  5. Replies: 0
    Last Post: 10-18-2015, 08:28 AM
