1. xmostwanted559x's Avatar
    Today my phone shut off at 17% and kept restarting itself. Once I got home and plugged to charger battery was showing 5%. Now I have it charged to 55% and seems like its stuck at 55% even with me using it. anyone have this issue before
    10-21-2015 10:26 PM
  2. Jeff Jones9's Avatar
    Haven't had this issue before. I would personally factory restore it, ( backup your things of course ) If it is under warranty take it to the store and see if they can replace the battery or the whole phone. Also one thing to try is power the phone off, then put it on the charger. You should see the battery icon once you plug it in. See if it makes a difference. lol before that check the battery see if it seems hot or swollen.. If so take it out!!
    10-21-2015 11:05 PM
  3. muzzy996's Avatar
    Sounds like a faulty battery.
    Sent from my SM-P900 using Tapatalk
    10-22-2015 12:30 AM
  4. natehoy's Avatar
    Fastest and cheapest attempt at a fix is a replacement battery. That sounds like a classic case of one of the cells failing if it can't maintain consistent voltage cycles. This is not good for your phone, so get a replacement ASAP.
    If you go into your carrier store, they may be able to warranty replace one right there. If not, you can mail order one for under $20.
    10-23-2015 07:20 AM
  5. goin_nil's Avatar
    I use these replacement batteries from Anker. They work very well and are very inexpensive.
    http://www.amazon.com/Anker-Replacem...cUvbUpU4771817
    PookiePrancer and huntnyc like this.
    10-24-2015 03:54 PM
  6. delco714's Avatar
    How coincidental...My battery just started discharging really quickly the last two days and shutting down at 15-20% ... Hmm. Guess I'll buy a new battery
    10-24-2015 06:11 PM
  7. clownin72's Avatar
    I've noticed my battery life getting worse lately and tonight it just done the same as others here described. Got down to 11% then instantly dropped to 4% and then went into repetitive restarts for about 5-6 cycles then dead. Has anyone confirmed that a new battery fixed their issue?
    10-27-2015 09:31 PM
  8. Liquidretro's Avatar
    I am seeing similar issues on 2 of the phones on my accounts. The worst shuts down at 40% often it seems. Anyone had luck with Verizon warrantying them? How about samsung?
    10-27-2015 10:21 PM
  9. Jeff Jones9's Avatar
    Anker makes GREAT products! Highly advise this manufacturer
    FSU30 likes this.
    10-28-2015 07:32 AM
  10. Liquidretro's Avatar
    Just an update, I called Verizon told them of the problems I was having and said I thought it was a battery issue. They are replacing my battery free of charge and overnighting a new one.
    10-28-2015 08:21 AM
  11. clownin72's Avatar
    Called them as well and after an hour of troubleshooting for nothing which I already knew, got a battery on the way
    10-28-2015 01:22 PM
  12. delco714's Avatar
    My battery on it's own stopped draining like crazy but it'll still die at like 11-15%. Hmm
    10-29-2015 10:54 AM
  13. tivoboy's Avatar
    I've been having this same issue, but never saw it before upgrading to 5.1.1..I think it has something to do with that update. None of us probably had the problem before?
    I regularly have very good battery life and that continues, but there IS one problem since 5.1.1.. on a sprint Note 4.
    Once I get down to about 12-15% I get an alert, battery is low, etc.. If I start to do something with the phone, open a browser or download an app, boom it just shuts down completely.
    I can reboot the phone, but it shuts down again. When I plug in the power, it says it is at 0% battery so either the battery meter is totally wrong or the battery is damaged?
    thoughts?
    I've reset the cache several times now, to no sucess
    11-04-2015 06:10 PM
  14. AZDROIDX's Avatar
    Get a new OEM battery, will take care of it.
    11-04-2015 11:23 PM
  15. kgk1985's Avatar
    Mine shut off at 16% the other day. Maybe I need a battery cuz my battery life has sucked. I assumed it was just ****ty lollipop
    11-05-2015 01:37 AM
  16. joklun's Avatar
    Lately my battery has also started to drop from around 15% to zero. Today it dropped from 21% to 4%, see image. Can it Battery Issue-uploadfromtaptalk1446753258267.jpgbe because of fast charging? Does a new battery solve the problem?
    11-05-2015 01:54 PM
  17. IslandGuy's Avatar
    Can anyone confirm that a new battery solved this issue? A few days ago I experienced the same issue and it occurred again last night so I am looking for a solution.
    11-12-2015 04:33 PM
  18. dabombcra's Avatar
    Lately my battery has also started to drop from around 15% to zero. Today it dropped from 21% to 4%, see image. Can it Click image for larger version.
ID:	204683be because of fast charging? Does a new battery solve the problem?
    I'm having the same issue. I'm glad I have the Note 4 so I can change the battery. It sounds like a battery issue. Time to get a new battery. That is what I'm going to do.
    11-15-2015 01:01 AM
  19. d4691's Avatar
    Agreed. I bought a OEM battery and charger for cheap off amazon. Nice to have a spare laying around.
    11-16-2015 06:45 AM
  20. IslandGuy's Avatar
    Ordered what I thought was an OEM battery on Amazon also but the reviews cast doubts as to their authenticity so I decided to return it for a refund. Went to T-Mobile to check if my battery was still under warranty, as it's less than a year since I purchased the phone. They ordered a replacement for me which will arrive in a few days. Hope this solves my problem.
    11-17-2015 06:21 PM
  1. Replies: 4
    Last Post: 11-13-2015, 11:01 AM
  2. Android system eating up my battery... what can I do?
    By an illegal mind in forum Samsung Galaxy Note 5
    Last Post: 11-10-2015, 03:08 PM
  3. Samsung Pay - battery impact
    By larryg in forum Samsung Pay
    Last Post: 10-23-2015, 11:05 AM
  4. Note 5 Theme issues
    By android_boi in forum Samsung Galaxy Note 5
    Last Post: 10-21-2015, 08:24 PM
  5. Replies: 0
    Last Post: 10-21-2015, 03:46 PM
