1. piannetta's Avatar
    Hi there, how do I control the behaviour of the LED in 5.1.1? Prior to upgrading, I used a third party app to define the color and flashing behaviour on a per app basis and it worked fine. Now, none of these apps work, even with their supposed workarounds enabled, and it seems Samsung have done something to stuff it all up. Any advice would be appreciated.
    10-27-2015 04:11 AM
  2. piannetta's Avatar
    Bump
    12-21-2015 03:18 PM
  3. pduffer's Avatar
    Sorry that I don't have an answer (nor 5.1.1 as I'm on Verizon), but what app did you use to define color and flashing behavior?
    12-22-2015 10:28 AM
  4. piannetta's Avatar
    Hi, I've used LED Manager and Light Flow.
    pduffer likes this.
    12-22-2015 03:20 PM
  5. grunt0300's Avatar
    Both of those apps should work, although i'm on AT&T.
    12-22-2015 04:09 PM
  6. piannetta's Avatar
    Thanks, Light Flow seems to work but the side effects are just plain annoying
    12-28-2015 05:51 PM
  1. missed call notification
    By madroxide in forum Motorola Droid Turbo
    Last Post: 10-27-2015, 11:09 AM
  2. Replies: 0
    Last Post: 10-26-2015, 11:41 PM
  3. Why can't I sign in to my phone after I wiped it?
    Last Post: 10-26-2015, 09:18 PM
  4. Galaxy S5 won't connect to mobile data after turning off wifi
    Last Post: 10-26-2015, 09:17 PM
  5. Phone contacts after 5.1 update
    By bigbadwulff in forum Moto X (2014)
    Last Post: 10-26-2015, 09:00 PM
